OHC-6 TECH Over Head Cam projects, questions and advice.
Old 08-05-2023, 10:50 AM
afantasi@gmail.com afantasi@gmail.com is offline
Default 230 and 250 Pontiac OHC heads
Are 230 and 250 OHC heads interchangeable or are they different
Old 08-05-2023, 02:25 PM
Cammer-6 Cammer-6 is offline
without including the AIR and export heads and minor casting changes there are 6 heads.
Compression ratio was determined by combustion chamber size.
66 1 bbl
66 4bbl both have short spark plug
67 1 bbl
67 4bbl longer plug,same as 68-9
68-9 1bbl this is the largest combustion chamber,lowest compression ratio
68-9 4bbl very close to 66 and 67 1 bbl combustion chamber size
so what makes this so important is a mix and match of components can alter
the compression drastically.
highest will be a 66-7 4 bbl head on a 68-9 250
lowest a 68-9 1bbl head on a 66-7 230
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 08-05-2023, 04:16 PM
Thanks, camper-6
230 is in my 1961 jag MKII sedan and needs a rebuild.
Have an extra head but need to identify before I use it if 230 head needs replacing.
