Been getting occasional cut outs at hard acceleration up around 5k in 1st gear. Been going back and forth between fuel pump or ignition.
Thought it was the pump since the tach stayed at the RPM. The coil was still sending a signal to tach. 3 days ago it cut out at cruising speed, but after 2 seconds it fired and I kept going. Yesterday, I had to have it towed home. AAA to the rescue. I was sure it was the fuel pump. Once home I verified there was no gas squirting, but there was fuel after all. So I pulled a plug, no spark, but there was a signal off the coil primary to the tach and I could get a dwell reading while cranking. It is a points system. New FAST coil, new Blue Streak ignition parts. No broken wires. Tests I’ve performed so far are suggesting the solenoid. My thoughts are that would prevent it from starting, but why would it kill it once running when the starter isn’t doing anything anyway. Other possible items could be the ignition switch or perhaps it’s at the bulkhead connector. More testing after work today. |
Tach and dwell signals working while the problem occurs hints that the problem (if electrical) is in the coil, the rotor or the high voltage wire from the coil to the distributor. Does a timing light fire when the problem is occurring?
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
| The Following 2 Users Say Thank You to Bill Hanlon For This Useful Post: | ||
With the age now of these point distributors many times I have seen the insulation dry rotted off the wire that runs under the plate to the points.
This can make for intermittent shorts and no spark and with enough time and bad luck a 100% short all the time. I have had two cases of this where the visible part of this wire above the plate still looked good, so don’t be fooled. Check for a short with a ohm meter, or just be on the safe side and replace that length of wire back to the coil.
| The Following 2 Users Say Thank You to steve25 For This Useful Post: | ||
My experience is that if the ignition cuts out while running under load, you will get a backfire thru the exhaust. When the ignition cuts out, unburned fuel gets into the exhaust, then when the ignition fires up the unburned fuel gets lit.
George
| The Following User Says Thank You to george kujanski For This Useful Post: | ||
I have not checked any induction on the coil wire with the timing light yet. I did pull it off the dist and held it next to a ground strap while cranking. It didn’t arc. Appears to be in the secondary circuit since the coil is getting feedback from the points, it appears the primary circuit is OK.
WHICH FAST coil?
The PS50 and PS60 would not be compatible with points. PS20 and PS40 should be. Others may/may not be compatible. |
| The Following User Says Thank You to Schurkey For This Useful Post: | ||
If you have a multimeter check resistance / continuity between carbon button inside and center coil post terminal on outside of cap
........... The More You Follow The Herd The Less You Can Be In The Lead .......... |
Had an internally shorted sparkplug cause a great pause with exhaust report.
| The Following User Says Thank You to Half-Inch Stud For This Useful Post: | ||
Change you condenser then you might try a different coil.
Update. Did a few more simple tests with the Flukemeter and culprit was revealed.
It was THE COIL! What a shock. HA! Pulled out the old MOTOR manual to see what the ohm range should be. The primary was within spec, the secondary circuit was fried. Over 900 ohms. Should be single digits. 3-4 ohms. Had an old Delco 202 coil in the shed and it popped right off. So much for the F.A.S.T. replacement coil I installed last fall. What a piece of junk. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to MPKind For This Useful Post: | ||
It was a PS40 for points. It failed after less than 1000 miles. Sent from my iPhone using Tapatalk |
What year car was this in?
In early cars without an ACC position on the ignition switch leaving the key in the run position without the engine running can cause coil failures especially the aftermarket high output versions. The original OE coils were more durable and you were more likely to burn the points up first while listening to the radio at your local make out spot. But with a modern electronic ignition system the coil becomes the weakest link.
If it breaks. I didn't want it in the first place. _____________________________________________ 69 GTO \ 72 FIREBIRD \ 1/2 OF A 64 GTO \ 70 JAVELIN \ 52 FORD PU \ 51 GMC PU \ 29 FORD PU \ 85 ALFA ROMEO SPYDER \ A HANDFUL OF ODD DUCATI'S \ 88 S10 LT1 BLAZER & MY DAILY DRIVER 67 SUBURBAN. |
Secondary would be hundreds or thousands of ohms. Lots of turns of fine wire. That's really disheartening. I've got a couple of the similar PS50 (for electronic ignitions) still in the box. Wondering if they changed the design. Used to be advertised as "oil-filled", now they're jabbering about "epoxy-filled". |
I had it flipped…long day. It was the primary that failed. Secondary resistance was ok.
Correction. It was a PS20 coil. |
That coil is designed to be used on 9 volts other then when cranking.
Are you running that off of the ballast resistor it shipped with ?
One thing for all to keep in mind and that few seem to know who do not have a electronics background is that you should never crank over a a motor with a main / central spark coil for more then 5 seconds with no place for the spark to go, as in no plugs hooked up, or the cap off but everything else hooked up.
When the coil is still being triggered the coils secondary side is still producing a spark and with no way to get that high voltage produced to ground the coils secondary winding will arc across itself. The higher the secondary voltage the coil is designed to produce the more likely it will be for that voltage to arc thru the enamel insulation used on the wire of the secondary. On a factory 45 year old spark coil the insulation on the coils secondary windings is likely already compromised and ready to fail just due to vibrations and heat cycles, so don’t push it over the edge!
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 08-09-2023 at 08:23 AM. |
As for the vintage part. Clearly it’s proved to more durable than the FAST coil. I was using it awhile last fall when I ordered the FAST coil. It’ll do until I find the right replacement. Needs to be the correct diameter to fit the coil bracket. Most after market coils are slightly bigger than the Delcos so they don’t fit. Back to the drawing board. |
I stand corrected. Ballast is required with the PS20/40 coils by FAST. “The large print giveth, and the small print taketh away.” It failed because it burned out from overload. I f’d up and purposely left the ballast off the car.
Can we sell a coil that doesn’t require additional parts to operate properly? Is it too f-ing hard to sell a product that’s similar to the original in setup and appearance? If it’s a Mopar or similar swap the ballast, but on a mid 60s GM Delco system? No. |
I suppose I could find a longer clamping screw and bolt. |
