Old 08-17-2023, 06:23 PM
Skidmark's Avatar
Skidmark Skidmark is offline
Default Having trouble nailing down the origin of my rearend
I bought a 12 bolt rearend from a good guy on py forum. He pulled it from a running Lemans we know it was not original to that car. He thought it was from a Chevelle.
The cast code 3959038 shows 1969 Chevelle maybe early 70.
The axel code was stumping me it is L S with E under those letters.
Born date -0422(letter missing)-
Has what appears to be factory gears 2:73
The Pontiac Manal list L S 2:73 for 1970 GTO/GP not sure if they mean 12 bolt or 10.2 doesn't say.
The E should be Eaton it is a posi unit.
One of the things I'm trying to figure out the 3959038 cast shows late 69 some docs say maybe early 70.
So I would think I have rearend out of a 1970 GTO, would date 0422 April 22 1970 still be considered early 70.
Date numbers 0422 I thought would be late production date for 1970
Thanks Chris
Old 08-17-2023, 08:01 PM
1968GTO421's Avatar
I expect that 'ol Pinion head will be your go to guy for good info on your rear end. Best of luck.
GTOAA--https://www.gtoaa.org/
The Following 2 Users Say Thank You to 1968GTO421 For This Useful Post:
Old 08-17-2023, 09:12 PM
a guy named skidmark worried about his rear end... user name checks out
The Following 2 Users Say Thank You to Scarebird For This Useful Post:
Old 08-18-2023, 12:45 AM
The rear in question is a '69 Buick Skylark or Olds Cutlass rear mfg by McKinnon Industries in Canada. Many Oshawa built nothing special '69 Buick & Olds A-body's received this style rear & in the 2.73 ratio. Have pulled several of these two letter L coded McKinnon 12 bolts as cores.
This is a c-clip axle 12 bolt Chevy style rear originally assembled with a 3R pinion flange & it should have backing plates w/o the spotwelded on flanges. As coded & originally assembled it had a 2.73 (high ratio) 12 bolt Eaton posi carrier. Any sources listing the two letter L code 12 bolts as '70-72 GTO usage are mistaken. McKinnon also built some 12 bolts for Chevy A-body applications, those will have the common spotwelded flange style backing plates, small Chevy 1310 ujoint flange, or if a 278 casting & out of a higher horse 70 Chevelle, the 1330 style ujoint flange.
The Following 4 Users Say Thank You to 'ol Pinion head For This Useful Post:
Old 08-18-2023, 01:15 AM
dataway's Avatar
dataway dataway is offline
OPH ... I hope you write a book before too long.
The hobby needs this kind of info.
Old 08-18-2023, 05:13 AM
Skidmark's Avatar
Lol
Old 08-18-2023, 05:14 AM
Skidmark's Avatar
Thanks for the excellent info.
Old 08-18-2023, 06:59 AM
mgarblik mgarblik is offline
o'l Pinion head: Tremendous wealth of knowledge on Rear ends and so much more. Really enjoy your posts. Seriously think about somehow storing some of your knowledge in some form. So much knowledge from our carb. ignition, and other experts on this forum.
The Following 4 Users Say Thank You to mgarblik For This Useful Post:
Old 08-19-2023, 05:46 PM
Skidmark's Avatar
So I originally thought I had a US built Chevrolet 12 bolt rear series 2 .Meaning that without using spacers the 2:73 ratio was the highest gear set I could use.
Now that OPH has explained that the evidence in fact proves I have a 1969 Canadian built GM 12 bolt 2:73 posi out of a Buick/olds built for Canadian use. I'm wondering if I'm still at my limit for high gears with the 2:73 in this rear?
Really wanted something in the low 3's posi.
Also the yoke is damaged on the case. The u joint measures 3 5/8 across which I think should be the 1330. Which I believe is what OPH said I should expect. Yoke appears to be early u bolts not strap. Any idea where to find a yoke? I haven't cleaned the one I got to see if numbers exist.
Thanks Chris
Old 08-19-2023, 05:57 PM
Skidmark's Avatar
Here are a few pics.
ID:	618466   Click image for larger version
ID:	618467   Click image for larger version
ID:	618468   Click image for larger version
ID:	618469   Click image for larger version
