Old 08-23-2023, 08:57 PM
rickschabener's Avatar
rickschabener rickschabener is offline
Default 68 ram air lower foam alternative?
Hello Everyone,
I've had my car for 45 years and had to change the Ram Air foam seals every 6-7 years because they turn to mush and fall apart.
Does anyone make these out of rubber, or a better quality foam? I know foam is correct, but I'd rather have something that I don't have to change so often.
Can the rubber seal from a Camaro be adapted to fit?
Has anyone come up with an alternative to the factory foam in any way?
Thanks,
Rick
Rick
The Following 2 Users Say Thank You to rickschabener For This Useful Post:
Old 08-23-2023, 09:01 PM
Cammer-6 Cammer-6 is offline
before they offered repops I made some out of a sheet product called Armaflex
Its still a foam but is industrial so its much heavier.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 08-23-2023, 09:24 PM
65madgoat's Avatar
Well the foam reproductions I am buying the past decade all seem to last and I drive often and have not had them deteriorate. Moroso sells a universal foam maybe you can get to work. But for under $100 the cost of a correct shape foam is hard to beat even if it lasts only 5 years for you.
