Old 08-25-2023, 07:35 PM
gman005's Avatar
gman005 gman005 is offline
Default 69 Lemans header gaskets.
A friend of mine has a 69 Lemans with header gasket leaks. The heads are 47's I think he should put manifolds on it and loose the headers. What do you think?
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 08-25-2023, 08:42 PM
steve25 steve25 is offline
Sure if he does not mind giving up 15 Hp and 3 mpg.
Old 08-26-2023, 04:28 AM
Kenth's Avatar
Kenth Kenth is offline
I guess he is not racing his 350 with #47 heads?
Headers are for race cars and racers don´t mind regulary changing leaking gaskets as they always have something to repair on their cars.
The power loss may be at 5000 rpm´s and i don´t think he will notice any power loss under normal driving conditions using stock manifolds.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 08-26-2023, 07:37 AM
grivera's Avatar
grivera grivera is offline
Quick question re headers vs manifolds. If he removes the headers and installs let’s say RA manifolds, will the down pipes easily line up with the exhaust? That is, do headers typically have the same spacing, width where they meet the exhaust as down pipes?
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 08-26-2023, 07:44 AM
scott70's Avatar
scott70 scott70 is offline
I've done the headers to manifolds thing,...both of mine ended up being in that 19 to 20 inch center to center for the head pipes. As far as getting rid of the headers and go to exhaust manifolds on the 350,,,definitely.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
The Following User Says Thank You to scott70 For This Useful Post:
Old 08-26-2023, 08:14 AM
Singleton Singleton is offline
Headers are probably leaking because the 47 heads don't have the bolt holes drilled and tapped on each end. Has 4 bolt holes instead of all 6
66 GTO, 495, M22, Strange S-60 w/4.10
Sold new at Ace Wilson's Royal Pontiac
http://www.youtube.com/watch?v=cUHC-Z8xhtg
Old 08-26-2023, 11:03 AM
gman005's Avatar
Singleton you are correct. I just want to fix it and be done with it. So does anybody have a pair they want to sell?
71 Lemans Sport.
72 Lemans Sport.
Old 08-26-2023, 11:04 AM
gman005's Avatar
You can call or text me at 708-204-7341 Thanks John
71 Lemans Sport.
72 Lemans Sport.
Old 08-26-2023, 01:18 PM
The 47 castings indeed do not have the outer bolt holes to seal up the end exh ports as needed.
Don’t go looking at the Pontiac 350 in the the light as a Chevy 350 when it comes to its response to headers.
The Pontiac 350 has a lot more stroke !
Old 08-26-2023, 03:47 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Try your luck with Remflex gaskets, much easier than taking headers off.
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
The Following 3 Users Say Thank You to OCMDGTO For This Useful Post:
Old 08-27-2023, 06:49 AM
Just in general and from what I have seen over the years in terms of failed header gaskets is this.
If your motor mounts are worn and allowing the motor to rock more then normal then the headers being bolted to the exh system are put into the position of trying to hold the motor in place.
This will sheer the gasket no matter what is made of and a leak will develop sooner or later.
If you have headers with a narrow welded sealing lip then all the movement gets concentrated there and then any movement not only burns them out, but that narrow sealing lip chews thru the gasket due to the concentrated loads there.
I have always used a good slathering of anti- seize on both sides of my header and collector gasket’s do they if need be can slide on each other without getting torn up.
The Following 2 Users Say Thank You to steve25 For This Useful Post:
Old 08-28-2023, 12:46 AM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
We have had excellent results with the RemFlex header gaskets .... I would probably try a set of those first, before changing headers out.....
1978 Trans Am
Pump Gas 461 Stroker
The Following 2 Users Say Thank You to TransAm 474 For This Useful Post:
Old 08-28-2023, 09:08 AM
gman005's Avatar
We are going to try the Remflex gaskets 1st.
71 Lemans Sport.
72 Lemans Sport.
The Following User Says Thank You to gman005 For This Useful Post:
Old 08-28-2023, 07:53 PM
Vid's Avatar
Vid Vid is offline
I like the Remflex material, they will definitely help prevent
leaks. Just double check the fit and the cut of the gaskets. I don’t know about D ports, but the cuts for the two center bolt holes on the Remflex for round ports was off enough that the bolts wouldn’t nearly go in. Had to pull the gaskets out and trim them up, surprisingly more than a little.
The Following User Says Thank You to Vid For This Useful Post:
Old 08-28-2023, 08:27 PM
MatthewKlein MatthewKlein is offline
Without the end bolt holes anything you end up with could leak. Crazy that some heads don't have all the holes.
I've had the same headers and gaskets on my 440 for around 20 years. Back then I asked my machinist about copper gaskets and other fancy stuff. His opinion was that header leaks come from loose header bolts. I've been safety wiring my headers and its eliminated problems.
The Following User Says Thank You to MatthewKlein For This Useful Post:
Old 08-29-2023, 02:08 AM
1969 was the year the factory began producing some exhaust manifolds without the end bolt holes. I guess they decided they could save money that way, usually that’s the reason.
In 1965 both the manifolds and heads had all 6 bolt holes but they assembled the manifolds to the heads using only 4 bolts, there are pictures of 1965 GTO engines built that way sitting and waiting at the factory.
Usually the big-valve performance heads would have all 6 bolt holes drilled and tapped (1969 #62 & #48) but the low performance small valve heads (#46 & #47) had all 6 bosses cast into the head but only 4 were drilled and tapped.
Even some of the round-port heads (1971 #197 & 1972 7F6 455 HO heads) had only 4 bolt holes drilled and tapped, if you want to run headers you have to drill and tap the end bolt holes. The exhaust manifolds used on these heads were held on by only 3 bolts if that doesn’t sound crazy, the way the manifolds were cast only allowed for one bolt for the center two exhaust ports.
In a nutshell the factory didn’t give a damn if headers would seal or not, the exhaust manifolds sealed up fine with 4 or even 3 bolts in some instances.
Old 09-04-2023, 02:01 PM
gman005's Avatar
Well I put the remflex gaskets in with no more exhaust leaks. I told my friend do not bring that oil and coolant leaking pos back. LOL
71 Lemans Sport.
72 Lemans Sport.
The Following 3 Users Say Thank You to gman005 For This Useful Post:
Old 09-04-2023, 04:01 PM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
If you got headers: Remflex, Remflex, Remflex.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
The Following User Says Thank You to nUcLeArEnVoY For This Useful Post:
Old 10-24-2023, 11:12 PM
grivera's Avatar
My 1969 47s have bolt holes on the ends. Should I assume they were added?
Will Rivera
Old 10-25-2023, 07:55 AM
400 Lemans's Avatar
400 Lemans 400 Lemans is online now
What does that stamping say on the front of your heads? May have had some good work done to them.
