Old 08-25-2023, 10:03 PM
boardog boardog is offline
Default # 48 heads
i bought a 1970 ram air engine that had been removed from a 24k mile 70 t/a years ago due to a spun rod bearing . It had a set of #48 heads that were both date coded H-20-8. My question is would these be very late 68 heads or very early 69 heads? I thought yearly change over was either August or Sept.
https://www.dropbox.com/scl/fi/hcwwg...fappqnmq0&dl=0
https://www.dropbox.com/scl/fi/d63l3...7hmyhxc12&dl=0
Old 08-26-2023, 04:32 AM
Kenth's Avatar
Kenth Kenth is offline
#48 heads were used on 1969 engines, no exceptions.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 08-26-2023, 08:17 AM
That is what i thought. So these are a early production head?
Old 08-26-2023, 08:25 AM
comanchefirebird comanchefirebird is offline
Seems like Pontiac cast a lot of 48 heads in August of 68. They were used on 69 Firebirds and GTO's built that fall and likely into early 69 with 400HO or RAIII 4 speeds.
