Old 09-03-2023, 05:35 PM
TheCirque TheCirque is offline
Default 81 TA “Wired” Dash Bulb Locations… help.
Im replacing printed circuit board on back of gauge cluster. I also replaced a couple bulbs. I have two wired bulbs coming from car harness that need to plug into back of cluster that do NOT use the orinted circuit board. One, i know is check engine light bulb. Its obvious as there is a “gap” in printed circuit for this wired socket. The other one is Not so obvious. Can someone help me out? Ill attempt to post pics. Thx.
ID:	619340   Click image for larger version
FUEL IS FREEDOM
Experience: What you get when you don't get what you wanted.
Old 09-03-2023, 08:54 PM
Never mind… id delete this post if i could figure out how.
FUEL IS FREEDOM
