Old 09-10-2023, 08:17 AM
64speed's Avatar
64speed 64speed is offline
Default Sway bar frame threads.
Long story short one of the frame threads for the front swaybar holes stripped out. What’s the best fix? I don’t think it’s thick enough for a helicoil
Old 09-10-2023, 09:15 AM
steve25 steve25 is offline
This topic has been covered at nauseam , learn to do a search.
The Following 4 Users Say Thank You to steve25 For This Useful Post:
Old 09-10-2023, 09:17 AM
64speed's Avatar
So oversize thread cutting bolt?
Old 09-10-2023, 09:26 AM
78w72 78w72 is offline
Rivnut.
The Following 3 Users Say Thank You to 78w72 For This Useful Post:
Old 09-10-2023, 09:49 AM
64speed's Avatar
Originally Posted by 78w72 View Post
Rivnut.
Ok I searched that and came up with a harbor freight kit. Is that sufficient?
The Following User Says Thank You to 64speed For This Useful Post:
Old 09-10-2023, 10:21 AM
Harbor freight should be ok but probably cheaper material, i get mine from fastenal for about a buck a piece.... can use a normal bolt/washer set up to install, dont need to buy the special tool, especially if you will only use the rivnuts one time.
lots of youtube vids on how to install them without the tool but works eaither way.
you can tap it to the next bigger thread size, but then you will always have 1 bigger bolt, the rivnuts are basically permanent and let you keep the same bolt size.
there was a recent thread on this, i posted a couple vids showing how to install them without the tool.... here ya go. https://forums.maxperformanceinc.com...ghlight=rivnut
The Following 2 Users Say Thank You to 78w72 For This Useful Post:
Old 09-10-2023, 10:35 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
For the large 1&1/4 front sway bars on later Formula and Trans Ams the factory used Riv nuts. On the Camaros with their smaller front bar just drilled self tapping bolts in the frame.
Skip Fix
Old 09-10-2023, 10:41 AM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
I believe steve25 meant search THIS forum. This topic has been discussed at length and a lot of good info has been posted on the various repair methods.
Old 09-10-2023, 10:57 AM
TB1's Avatar
TB1 TB1 is offline
If you want to get it down without waiting for parts or tools to arrive, get a telescopic magnet and a 3/8 x 1.25 NC bolt and nut and lock washer drill out the hole in the frame and install, This is what I have done on my 65 with all four is it a hack fix, possibly but I didn't want to buy the Rivnut set and a bunch of wasted time waiting when I could of been driving.
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt
The Following 2 Users Say Thank You to TB1 For This Useful Post:
Old 09-10-2023, 11:10 AM
64speed's Avatar
I know what he meant. I searched rivnut cause I had never heard of it.
Old 09-10-2023, 11:44 AM
Are you sure thats the case for all later 2nd gen formula/T/A? I have an 81 WS6 T/A and pretty sure only the frame is tapped, thats the car i bought the rivnuts for, no other threaded inserts inside the frame I could see when repairing the stripped hole. Pretty sure my 78 WS6 T/A is the same but will have to check next time its out.
Old 09-10-2023, 11:54 AM
Skip Fix's Avatar
My 78 and 81 has rivnuts but instead of an allen head bolt like my 78 had small head bolts.
79 Camaro none.
I think rear brackeri just threads.
Skip Fix
Old 09-10-2023, 12:12 PM
I will have to double check my 81 & 78, i know the 81 didnt have them when i recently fixed a stripped hole... either someone removed all 4 factory rivnuts & tapped the frame or maybe its a norwood vs van nuys thing?
Old 09-10-2023, 01:58 PM
imposter's Avatar
imposter imposter is offline
stick a wrench in the frame and put a nut in there or drop a bolt down with a magnet
Old 09-10-2023, 02:03 PM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Careful with rivnuts. Most people do poor install on them, and they end up becoming an issue. My car for instance, somebody put in rivnuts on stripped out frame threads and 3 out of 4 of them just spin in their holes. My sway bar bushings aren't in too bad of shape so I've just not bothered doing anything about them for now.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
Old 09-10-2023, 02:07 PM
Skip Fix's Avatar
yea I always wondered abut that happening. i guess maybe a tack weld woud fix it?
Skip Fix
Old 09-10-2023, 02:23 PM
Theres a chance the ones on your car are factory installed based on what skip fix posted.
Now that I think of it, my old 78 T/A i had as a teenager & into my mid 20s had some type of threaded insert in the frame for the sway bar, one side they were spinning so a friends dad put a tack weld on them from the factory side holes in the frame.
Old 09-10-2023, 02:26 PM
64speed's Avatar
I don’t see where I can get to it
Old 09-10-2023, 04:13 PM
72projectbird's Avatar
I did that on my 71. I kept ripping the threaded inserts out of the frame, so I said screw it and just bolted it in with a regular nuts and bolts.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 09-11-2023, 09:53 AM
HWYSTR455's Avatar
There's a difference between a rivnut and a thread-sert. Both types come up on searching either of the 2 types, so KNOW what you're buying before you buy.
Have to use steel inserts, and the steel inserts of the rivnuts is what is used, so you can't use the 'plyers' type of tool, it has to be the longer arm type of tool.
I've mentioned this before, but you have to drill the proper size hole, and depending on the size you need, you will most likely have to by a fractional drill bit that's not normally available in sets, or even some hardware stores.
When a rivnut fails (spins), 99.999% of the time is because the incorrect hole size was drilled. Once it spins, you can use the size rivnut you used before, you have to go bigger.
Problem is when you go to a bigger hole, the bolt heads get bigger, and may not fit due to the U bend of the bar bushing bracket.
If you can reach in from the front of the frame horn, you could make a plate with 2 bolts in it, and fish it into the frame, having the bolts drop thru. You can use a steel plate and tap holes so the bolts don't have to be welded, etc.
You might have to take the front bumper off to get to the front opening of the frame horn.
