Old 09-11-2023, 06:31 AM
nh68gto's Avatar
nh68gto nh68gto is offline
Default Doug’s vs ….
So I can’t find the repop Ram air manifolds anywhere now headers are last resort.
So are Doug’s worth the added cost or not.
Existing exhaust is set up for headers, that I threw away. Didn’t want to run them again. Bought the down tubes for the ram airs now un available.
Ughhhh…
Send it! It’s going home on a trailer.
Old 09-11-2023, 10:01 AM
74Grandville 74Grandville is offline
Dougs are very nice. I would get the Cermic coated ones.
1979 Firebird Trans Am 301/4spd (Now 428)
1977 Firebird Formula 400/Auto
2007 Grand Prix GXP 5.3L
Old 09-11-2023, 10:03 AM
78w72 78w72 is offline
I dont have dougs on my cars but have seen them on some 2nd gen firebirds, didnt see anything that justified the added price compared to other better priced headers like hedman or hookers etc.
I use hedmans on a 2nd gen that fit great & are leak free after 15+ years using the cheap supplied paper gaskets, use hooker super comp O-ports on another car that are very nice , using mr gasket graphite steel core type gaskets & are also leak free.
The key to leak free headers that most people dont do, is to retorque all bolts after a few heat cycles and check periodically once or twice a year, they arent manifolds so you cant just install & forget them or they will eventually leak and people blame the headers or gaskets, never used or needed expensive remflex gaskets on my headers. also use a locking type bolt with a small head, i use summit stainless header bolts with serrations under the head to help stop from moving, very cheap price and work great.
Nothing wrong with dougs, but there are other very good headers for less money. Also if you have a local powder coater they can probably coat the headers, will be much better quality than buying them coated from what Ive seen... probably cheaper priced too.
Old 09-12-2023, 12:57 PM
ZeGermanHam's Avatar
Options for headers that fit well will vary somewhat by what year A-body you're working with. I could be mistaken, but I think the '68-72 cars have a few more header options that fit better than do the earlier cars. I know that for my '66, Doug's is just about the only option worth using. All the other options either require dinging a primary tube (not a big deal) and/or they hang down lower than needed and can cause ground clearance issues. I was in the same boat as you, where I wanted to use RARE oversized manifolds for my car, but after waiting over a year and a half for them to show up (and repeatedly being told they would ship "next week"), I cancelled my order and bought Doug's ceramic coated headers. They fit beautifully everywhere, and don't hang down too low. Installation was pretty easy from underneath the car.
Would I have been happy with RARE manifolds had I been able to get them? Yeah, very likely. But I'm also extremely pleased with the Doug's headers, so ultimately I'm happy with how things turned out.
1998 BMW 328is (track rat)
Old 09-12-2023, 05:27 PM
taktikian taktikian is offline
Default Dougs
Will probably result in more ponies also
Old 09-12-2023, 07:08 PM
It does: https://www.motortrend.com/how-to/hp...-vs-manifolds/
Old 10-18-2023, 11:42 AM
02Hawk's Avatar
02Hawk 02Hawk is offline
In my opinion, Doug's are the superior choice in headers. They fit better, are easier to install and don't leak at the flanges.
I have a set of Hookers on my drag GTO.....they are usually a 4 hour install that requires lots of swearing, 4 hands and skinned knuckles. The Doug's by comparison, I can do my self in half the time without injury and having to wash my mouth out with soap.
Both do require some massaging with a BFH to get around the frame on the drivers side.
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright"
Old 10-18-2023, 01:32 PM
Lee's Avatar
Lee Lee is offline
Ram Air Restorations is listing their manifolds as "in stock" - is that incorrect? https://www.ramairrestoration.com/po...o-v8-2151.html
I recently put a set of Doug's on a '68 Firebird. I've installed dozens of sets of headers in my life, and these were about the best I have seen. Using 5/16" head bolts, I am able to put a geared wrench on every bolt, and did not have to modify any of the tubes for clearance. From headers on the ground, to installed with gaskets and all 12 bolts tight, it took me less than 45 minutes.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 10-24-2023, 05:46 AM
chuckies76ta's Avatar
Lee, Any chance you could post the size and part number please. Thanks
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
Old 10-24-2023, 07:42 AM
Lee's Avatar
Lee Lee is offline
Doug's D569, 1.75" primaries.
Header bolts I use in video: ARP 400-1109
Header gaskets I use: FelPro 1424
Link to video: https://youtu.be/EXBkWpQJJJU?si=xye5kcMwkmjbvrSo
The Following User Says Thank You to Lee For This Useful Post:
