Old 09-11-2023, 05:15 PM
nh68gto's Avatar
nh68gto nh68gto is offline
Lightbulb Hooker 4108
So it looks like a lot of the hooker headers are unavailable. Other than the Doug’s that come at a cost what fits the 69 GTO well. These are probably temporary because the Ram air manifolds are unavailable at the time and I need something. On the cheap and painted will be ok.
Send it! It’s going home on a trailer.
Old 09-12-2023, 10:10 AM
78w72 78w72 is offline
I am very happy with hedman headers, i use them on 2nd gen firebirds, the fit is excellent and they are priced much better than the more expensive brands like dougs or the bigger hookers.
Old 09-12-2023, 11:12 AM
Default 'probably temporary'
What cam this engine have in it? moreover how much valve overlap does the cam have?
With a mild factory type cam, stock logs would work for temporary
Clay
Old 09-12-2023, 12:07 PM
srmmmm's Avatar
srmmmm srmmmm is offline
I also went with Hedman. They met nearly all the criteria of my build: A/C, Power Steering, D-Port, Turbo 350 and (drum roll) column shift. The factory shift linkage didn't quite clear, but there were no issues with forming the down rod in a universal linkage kit.
I also think the Hedman's sound better than the Hookers that were used for the dyno pulls.
https://www.youtube.com/watch?v=nxDtH_76piU
Old 09-12-2023, 12:25 PM
Main reason I used the hedmans on my 78 T/A is they were one of the only reasonably priced headers that would fit 4 speed transmissions.
