Old 09-25-2023, 10:42 AM
Mike S's Avatar
Mike S Mike S is offline
Default 12-1 on pump gas
My comp. is 12-1 and have been running VP c-12. Car has been 6.04 in the 1/8 at 3100lbs. I shift at 6400 and go thru the traps at 6600 (1/4 Mile). It is a 455 60 over with older E-heads, Cranking compression is 190lbs hot with carb wide open. Being the cranking compression is so low, do you think this would run on 91 octane? I would like to use it on the street for local shows and cruises.
I was thinking of making a pass with race fuel and then with 91. If it is detonating it will slow up correct? Could I hurt anything making 1 pass on 91?
Anyone familiar with water/meth injection? Would this help running pump gas?
Old 09-25-2023, 11:02 AM
Stan Weiss's Avatar
Mike,
Isn't 93 octane available at the pump where you live?
Stan
Pontiac Pump Gas List
Old 09-25-2023, 01:04 PM
Mike S's Avatar
All gas stations around me have 91. I have to look around to see who has 93.
Old 09-25-2023, 01:39 PM
Steve C. Steve C. is offline
93 Octane Gas Finder
https://www.zeemaps.com/mobile?group=1385950
There are other sources as well
Old information here:
Old 09-25-2023, 02:15 PM
Jay S's Avatar
Jay S Jay S is offline
A pass on 91 only sounds like a bad idea to me. Blend in some 91 with your c12 first, it might go quicker. Work your way down.
I tried something like that once, went to straight 91, thought the pumping compression was low enough it would work. We ended up draining the gas, cause it was pinging all the time even in park.
The Following User Says Thank You to Jay S For This Useful Post:
Old 09-25-2023, 03:45 PM
mgarblik mgarblik is offline
I honestly think you are on the ragged edge at that compression ratio even with aluminum heads. I would proceed carefully. If your engine has headers and a loud exhaust, you will likely not hear mild detonation and it can be damaging. The other wild card, is once you go to pump gas, you need that safety factor because you never really know for absolute certain what you are buying. Mistakes are made all the time at the gas stations and the wrong gas ends up in the tanks. With C12 or other race fuel, you know what you are putting in the tank. I recently put a new street engine together and it has 10:1 static compression. It will run on anything, 87 and up octane. Runs best on 91 no alcohol fuel. Fairly sure I am giving up 25-30 HP. with compression that low. If I was starting over, I would probably bump it up 1/2 point. Obviously, camshaft choice has a big effect on octane tolerance as well.
Old 09-25-2023, 07:20 PM
t money t money is offline
Have you looked into Snow Performance Boost Cooler Forced Induction Water Methanol Injection Kit. My understand it cooling the chamber in higher compression
The Following User Says Thank You to t money For This Useful Post:
Old 09-25-2023, 09:16 PM
Half-Inch Stud's Avatar
Water injection, without methanol is supposed to be better. Water Atomization is key. Adjust mixture! Vizard has a Youtube video on it.
https://www.youtube.com/watch?v=jextyKc2UN4
A decent lesson in doing water injection correctly.
Old 09-25-2023, 09:50 PM
opeliac opeliac is offline
It all depends on how much you are planning to drive it, and how comfortable you want to be...My old 455 was 11.8:1, and I drove it on 89 octane almost daily...It was jetted fat, and over the 5 years that I had it together, never had an issue...I even drove it to the track once and made several passes on the cheap fuel...I had a 1050 on it, and like I said, it was pig fat...I tried a holley 930 on it once, and that didnt work...
We've also ran numerous big block chevies the same way...Had a 14.5:1 496 in a DONK...He ran premium unleaded in it, and as far as I know, its been together over 10 years now(limited driving)...A 13:1 477, pump gas for years...
Lots of cam, and lots of fuel...Its not perfect, but its worked for years.
Old 09-26-2023, 07:09 AM
chiefbigb chiefbigb is offline
I run aviation fuel in my street cars. 100 octane low lead. If there is a small local airport around there they will probably sell you some. I get 50 gallons at a time in a drum. 6 to 7 dollars a gallon and lasts forever. No ethenol.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
The Following User Says Thank You to chiefbigb For This Useful Post:
Old 09-26-2023, 09:57 AM
grandville455's Avatar
grandville455 grandville455 is offline
Why not just switch over to E85 and be done with it..
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
The Following User Says Thank You to grandville455 For This Useful Post:
Old 09-26-2023, 01:37 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My Mopar buddy with a wide band on his carbed then Hilborn EFI would see wide ranges of the AFR between batches of pump gas. EFI can compensate some when the carb could not.
Skip Fix
Old 09-26-2023, 02:10 PM
PAUL K's Avatar
PAUL K PAUL K is offline
These high compression pump gas fallacies need to stop.... Someone might think you guys are serious!
Go fast, see Elvis!
Old 09-26-2023, 02:12 PM
PAUL K's Avatar
What you need to do is raise your compression ratio a few points and use 93 octane.... Then you'll make big pow'a!!!
Go fast, see Elvis!
Old 09-26-2023, 10:06 PM
R 70 Judge's Avatar
I second this
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 09-27-2023, 09:23 AM
Mike S's Avatar
the closest station with e-85 is 27 miles from me.
Old 09-27-2023, 09:59 AM
There may be something to this compression makes more power thing. May try that theory one day. I'm impressed with Mike's car.
Old 09-27-2023, 10:00 AM
Tim Corcoran's Avatar
With 12:1 you don't need 112 octane C10 would be more than adequate.
Tim Corcoran
Old 09-27-2023, 10:13 AM
U be the first!! lol
Darby
Old 09-27-2023, 10:20 AM
PAUL K's Avatar
Already did.... Bent two rods and popped a head gasket instantly. That was 10.5 with 93. Now after reading this thread I believe my mistake was the 93 octane. Most likely should have used 87 to keep it safe.
Go fast, see Elvis!
