Old 10-06-2023, 09:05 AM
Skidmark's Avatar
Skidmark Skidmark is offline
Default Trying to figure out how to remove fan switch
My fan only worked on one speed. Wondering how to remove switch without breaking something.
I tried pulling the part you push with your finger to adjust fan speed, but it's either stuck or not meant to be removed.
Old 10-06-2023, 02:10 PM
OG68 OG68 is offline
I'd check the heater resistor first for open elements.
Which speed is working?
Old 10-07-2023, 07:27 AM
tigergto's Avatar
tigergto tigergto is offline
If only the high speed is working, chances are it’s the resistor.
Old 10-07-2023, 08:32 AM
Skidmark's Avatar
It's been a while since I took it out of the car. I had a spare that I installed, but I think the second speed was not working. Thanks
Old 10-07-2023, 08:50 AM
tigergto's Avatar
If everything thing is working with the spare switch, then it’s not the resistor.
Old 10-07-2023, 11:13 AM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
I just changed one on my 70 GTO project. That part that you are talking about has to come off to remove switch. Using a pliers I wiggled it off very slowly. Chances are it will crack. I cracked the first one I did. Luckily my parts car had one and I was able to wiggle it off with no damage. Ames might sell new ones. Good luck.
Old 10-07-2023, 06:27 PM
Skidmark's Avatar
Thanks, I found the part. I'll try to get the chrome/plastic end off without breaking.
Old 10-07-2023, 06:32 PM
Skidmark's Avatar
True. Prior to posting this I didn't even know about the resistor. Learned something new. Again lol.
Old 10-07-2023, 07:12 PM
Wouldn’t hurt to take a look at the resistor. Should be on the right side of the AC suitcase near the POA valve. . Two screws hold it in.
If a heater car, it’s located on top of the heater housing inside the car.
Old 10-10-2023, 03:16 PM
Skidmark's Avatar
Thanks, will do.
