never had a problem from the parts i buy from Ames , but the sail panel do not fit right .Any one else had this issue
Looking at that they likely go under the rear trim
no i can not get it far back enough to make it fit Just checked the ones OER sells and the look more correct
Ok, and yes pics look like it goes over as shown. Can you roll it into place from side rather than push backwards?
when i install against the roof pillar it will not go any further back . cant stand when these repo parts don't work . i wonder why no one else had this problem i guess i will buy the ones from OER AND REPORT BACK TO INFORM THE OTHER GUYS IF THE FIT BETTER
| The Following User Says Thank You to grd777 For This Useful Post: | ||
I’d use nOS myself.
All well and good suggesting that if they were available.
Possibly some extra material/mold flash in the u shaped leading edge that hooks over the pinch weld in the front?
will check that thanks for the tip
Gastro, I Didn’t sell any nOS on Dayton, just rusty junk. I had a whole table of nOS, it all went back home. Other than the serious collector, people won’t pay for it.
i do and will for NOS .DO YOU HAVE ANY SAIL PANELS NOS
In all likelihood whoever you buy them from they come from the same source.
| The Following 3 Users Say Thank You to Norwood For This Useful Post: | ||
It really depends on where the factory drilled the original hole.
White/Blue 71 455 HO T/A Auto Blue/Blue 71 455 HO T/A 4 Sp White/Sandalwood 71 455 HO T/A 4 Sp White/Black 70 RAIII T/A M21/373 (stripper) Carousel Red/Black 69 GTO Judge 4 Sp 2002 Firehawk Red/Black 6Sp |
not worried about the hole .its were it meets the upper glass. thesE ones are for a 73-74 OER MAKES THE CORRECT ONES FOR 70-72 CHECK THEM OUT ON THE WEB AND YOU WILL SEE THEY ARE NOT THE SAME
