Tri-Power Tech 57-66 Tri-Power Talk
Old 10-21-2023, 10:04 PM
GtoFM's Avatar
GtoFM GtoFM is offline
Default Carb Tag Info Decode
I have 2 tripower setups, a 64 and a 66. The pic is the 64. I know what the 702xxxx means, but what about the letters/numbers stamped between the embossed lines at the bottom of the tag? Is there a data sheet listing these numbers?
Name:	Carb tags '64.jpg
Old 10-22-2023, 04:10 AM
Kenth's Avatar
Kenth Kenth is offline
This may help some.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 10-22-2023, 08:44 AM
GtoFM's Avatar
Thanks Kenth, I thought that might be a date code but had no clue on the others.
Old 01-19-2024, 09:00 PM
carbking's Avatar
carbking carbking is offline
Starting about 1957, the tags are also color-coded.
Jon
