Picking the engine up Friday. I'll post the dyno sheet then but it made 542hp and 581tq.
400 bored 4.155 Eagle forged crank 4.350 Billet splayed caps SRP flats Eagle H beam rods Melling 60lb pump Victor intake KRE 85cc d ports ported to 300 9 way billet double roller Holley 850xp Bullet solid flat tappet cam 250/256, 606/607, installed at 104 34deg timing Builder says carb is holding it back from full potential but I sold my Dominator as it was too much on the street for mpg. I'm happy with the results after a few problems with the build that the dyno found. Can't wait to get it on the Firebird and try it on the street. No track testing until next year as our season has finished now.
69 Firebird 472, Bullet SFT, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 11.14@120 |
The Following 4 Users Say Thank You to 461-69bird For This Useful Post: | ||
Sounds good!
What was the HP of the engine in your signature? ![]()
611hp 601tq. Solid roller cam with a 1050 dom but everything else the same as this build.
69 Firebird 472, Bullet SFT, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 11.14@120 Last edited by 461-69bird; 10-25-2023 at 01:55 PM. |
Cool.
Thanks for the info. It'll be interesting to see what it runs when spring comes around. ![]()
Glad to hear no damage was done with the low oil pressure issue.
Yes Steve, got lucky with that
At what rpm where your peaks showing up at?
I think he said torque was 4100 can't remember the hp. I'll have the sheet Friday
Very nice results.
....had an UD cam with the 104 LC just like that in a 472. The 104 LC was set to 100/108 for Street effect. Idle pulses out the tail pipe were impressive. Hmmmm, have a 1970 1050 sitting on the shelf, doing nothing for nobody now.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
Is an 850 carb really a restriction on a 550 horsepower engine? Hmm.
Headers are 1 3/4 or 1 7/8? |
The Following User Says Thank You to i82much For This Useful Post: | ||
Well he thinks it could make 600 with a bigger carb. Headers are stepped Maddog 13/4 to 17/8
any chance it wants more timing? 34 degrees seems low. compression?
Just curious how much bigger is he thinking?
Those heads with my 290b were best at 32 with 10.2 comp.
With the solid roller 34 at 10.75. Now 34 at 10.8 seemed the best He would like to see a 1000 or a dominator but that's not what I'm ever going to run so wasn't much point. Would be fun to borrow one at the track just for a few runs though.
Did they have an air hat on the engine dyno? It would be interesting to see how much air that combination actually used? Also, if no air hat, did they have a vacuum line on it for manifold vacuum?
The Following User Says Thank You to mgarblik For This Useful Post: | ||
Yes, like menshined above , a vacuum reading take below the Carb at 500 rpm below peak hp will tell you if your Carb is too small.
Why 500rpm below peak??
FWIW my 500" IA motor that dynoed 695 HP made the same with an 850 4150 as a 1050 Dominator on it.
I can tell you dynoing my friends 463 E head motor that made 640 HP with 2" headers we killed 40 hp swapping on my 1 3/4-1 7/8 Hedmans
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune 13.43@103.4-sold 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
![]() Quote:
Stan
![]() Quote:
Also on the carb issue I am running a QF 950 that I discovered is more than I need. Factory jetting was at 86/78. I am down to 82/74 and it is still rich, at least in warm/humid air. Will probably be pretty close when the cooler/drier fall air gets here.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.60 @ 126 so far... |
Thread Tools | |
Display Modes | |
