Old 11-07-2023, 10:33 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Default WTB: Tilt Column parts 70-72
Looking for various parts for 70-72 tilt columns. Parts must come from Tilt columns only.
Needed:
1. Upper collar for floor shift column (ignition key, blinker and tilt levers install here)
2. Auto Column Shift indicator lens and assembly, PRNDSL (mounts on top of column)
Will consider complete columns, but prefer just parts. If you have a junk column or two around that have these parts in decent shape, that would be ideal. But let me know what you have.
Thanks!
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
Old 12-03-2023, 02:50 PM
mrgto69's Avatar
mrgto69 mrgto69 is offline
Pypes Staff - Tech
Hi Todd. I have an assortment of column shift indicator lens & assys. Are you looking for one or several? I'll make you a deal on all of them... Here's what I have... Let me know... Mike
ID:	624346   Click image for larger version
Old 12-05-2023, 10:54 PM
Hi Mike, thanks for reaching out. As I look at your pics, I believe all of those indicators are for standard (non-tilt) columns. The tilt column indicator I'm looking for is slightly wider, including the spacing on the PRNDSL, and it's held on by only one spring clip. I appreciate the try! Thanks, Todd
Eric Mitten
Deuteronomy 8:3
Old 12-08-2023, 11:48 AM
mrgto69's Avatar
Pypes Staff - Tech
Interesting that GM did that. I have several tilt shift columns. I'll have to look closer at them.
