Ames Customer Satisfaction Forum Post a 'current' compliment, suggestion or issue with regard to an Ames service or product.
Old 11-09-2023, 12:58 AM
Rachelsdad's Avatar
Default PV117 Max Car Cover: Surprisingly poor fit
In May, I ordered a PV117 for my '63 Bonneville convertible, fully expecting to use it at the POCI convention this year. As luck would have it, the car wasn't ready to go, so only tonight did I have an opportunity to try it out (it is actually a Budge NeverWet, which is a pretty good cover).
Although it's a Budge size 5, setting aside the semi-custom fit vs full custom fit, the cover is simply way too small for the '63 (it might make it end to end on a '61 Bonneville or even a '63 Catalina, but I can't get it all the way down around the bumpers, and as a result, the sides ride up above the rockers. As expected from a semi-custom fit cover, it is baggy at the windshield and rear window.
I'm not looking for an adjustment at this point as I realize that I should have test fit the thing when it first arrived. I just wasn't expecting such a poor fit from a Budge cover. I think it would be good to add some type of disclaimer to the catalog listing, however.
I'm also somewhat spoiled, in that I recently had to procure two California Car Covers for my pair of '56 Safari wagons. They were considerably more expensive, but fit absolutely perfectly (and yes, of course, they are truly custom covers).
Lewis
Lewis Rosenthal
'63 Bonneville Convertible
'56 Safari
'82 Firebird SE
POCI #3596 (since 1978)
Old 11-14-2023, 04:59 PM
AMES-TECH's Avatar
AMES-TECH AMES-TECH is offline
Ames Tech Staff member
Rachelsdad, I apologize for the delay! Can you please send over some pictures and your information to myself? If we need to adjust how we have these listed or look for a replacement, we absolutely will. I look forward to hearing from you.
Thank you!
Kyler @ Ames
(800)421-2637
[email protected]
[/SIGPIC]
The Following User Says Thank You to AMES-TECH For This Useful Post:
Old 11-14-2023, 06:50 PM
Rachelsdad's Avatar
Done!
Thanks for following up.
Lewis
Lewis Rosenthal
'56 Safari
'82 Firebird SE
Old 01-18-2024, 12:31 PM
Rachelsdad's Avatar
Just a quick public note of thanks to you, Kyler, and the rest of the gang at Ames for staying on this situation and working with me to something of a resolution. I could not be happier with the customer service you've provided. I wish it were not so uncommon today, but there it is.
Thanks again for everything.
Lewis
Lewis Rosenthal
'56 Safari
'82 Firebird SE
The Following 2 Users Say Thank You to Rachelsdad For This Useful Post:
Smilies are Off
