Carb Issue/Question
I'm running a mostly stock 455 with 4X heads in my '69 GTO. Intake is a stock '69 casting, and I'm running an HEI distributor. The carb is a Quadrajet that decodes as coming from a '73 Buick 455. The car ran horribly when I got it - hard to start, poor idle, poor drivability.
I had the carb professionally built by a local guy with a lot of experience. He said the carb was a mess with mis-matched components, leaks, and missing parts. He gave it a very thorough rebuild. Now the car starts, idles, and cruises a lot better. But if I slam open the throttle at any speed, it bogs horribly for a second or two before it accelerates. My carb guys says that the accelerator pump is set to deliver the biggest squirt, and that the bog is a "lean" condition. He reasons that the 73 carb is probably set to run lean because of the emissions in place at that time. He says not to mess with the metering rods, but to go straight to the main jets and open them up to richen it across the board. I am not doubting his expertise, but will fattening up the carb help to eliminate this horrible bog at WOT? If it matters for this conversation, the engine tune seems spot on as far as timing, etc. The car starts easy, and runs fine on pump premium fuel. TIA for your input and advice! |
Sounds more like you need to tighten up the rear flaps.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
The Following 3 Users Say Thank You to SRR For This Useful Post: | ||
There might be some pushback on this, but this is just something easy you can try that had an effect for me. Everyone likes to go round and round about what form of vacuum you should have your HEI connected to.
If you currently have your car setup so the vacuum advance is running on full manifold vacuum, try switching it to ported. When I had my Qjet I had basically the same thing. It ran great, but if I had it connected to full manifold and slammed the gas it would fall on its face. Put it on ported vacuum and the problem went away. Like I said, just something easy you can try that is easily reversible if it doesnt have an effect.
The Following User Says Thank You to RocktimusPryme For This Useful Post: | ||
#7043240 uses CT .0774" secondary rods which are way too lean for a healthy Pontiac 455.
I would replace these with a set of .0527" CV, AU or CK rods. Might even use .0440" DA or .0410" CE rods. As for preload on air valve spring start with 1/2 turn from zero and adjust in small steps towards 3/4 until bog is gone. |
The Following User Says Thank You to Kenth For This Useful Post: | ||
Is the carb using a white plastic choke pull-off?
Yes, white choke pull off installed.
That will be the culprit unless it's one of mine. At least 10 years ago, probably closer to 15 they changed suppliers for those. They have WAY too much spring in them and not enough restriction, so open INSTANTLY and don't dampen the secondaries.
The result is a huge stumble/hesitation/bog going quickly to full throttle. They also take 12-14" vacuum to apply them (factory spec is 5-6) so don't even do a good job unloading the choke on a cold start. Here is a link to one that applies at 5" vacuum and restriction installed to set the release time to prevent issues going to full throttle: https://cliffshighperformance.com/pr...pull-off-67-70
The Following 4 Users Say Thank You to Cliff R For This Useful Post: | ||
Cliff - thanks for the info. I just spent some time on your website. Looks GREAT! I'm very interested in your thoughts about fattening up my main jets or just going to a richer metering rod for my application, or is the choke pull-off the main culprit?
Start with the pull-off. It MUST have a timed release. A set of DA secondary metering rods wouldn't be a bad idea if the original rods are still in it. There still could be other issues. Worn/cracked secondary cam, tired secondary spring, hanger height, etc, but it will never work well with one of those newer white plastic pull-offs on it that open instantly......
The Following User Says Thank You to Cliff R For This Useful Post: | ||
Here is a pic of the pull-off. I used to do them in house but am currently sending them to an outside source to be "rebuilt" correctly.
They install the correct spring so the pull-off is fully applied at 5-6" vacuum and put a restriction in the inlet to time the release to prevent stumble/hesitation/bog going quickly to full throttle. That's why mine cost $30 and the POS stock ones are $10 shipped via Ebay.......
If you can read this, thank a teacher. If you can read this in English, thank a Veteran! https://cliffshighperformance.com/ 73 Ventura, SOLD 455, 3740lbs, 11.30's at 120mph, 1977 Pontiac Q-jet, HO intake, HEI, 10" converter, 3.42 gears, DOT's, 7.20's at 96mph and still WAY under the roll bar rule. Best ET to date 7.18 at 97MPH (1/8th mile), Last edited by Cliff R; 11-10-2023 at 07:57 AM. |
The Following 3 Users Say Thank You to Cliff R For This Useful Post: | ||
Do you know if the rebuilder replaced the secondary spring and cam?
Agree with Cliff on the CPO, but have seen some very worn cams and weak springs as well. Jon
"Good carburetion is fuelish hot air". "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
The Following User Says Thank You to carbking For This Useful Post: | ||
John, unlikely they did as no kits that I know of besides yours and mine come with them. I do NOT consider that an optional part of rebuilding the Q-jet. Even if the cam isn't worn down, cracked or melted, 99.9 percent of them are loose on the shaft from nearly 50 years of heating/cooling cycles, shrinkage, etc, and delay raising the hanger when the secondaries are called on. This results in the fat part of the secondary metering rods behing too far into the jet holes just long enough to produce a lean condition. It's one of the most difficult things to troubleshoot with one of these carbs because no matter what you do anyplace else it gets no better.........FWIW......
Who know whats done to your carb? And ignition? |
If part of the mod’s ever done to the carb are the drilling of 4 holes the tip in fuel pull over tubes as talked about in Doug Roe’s Q-jet book to be helpful, then that can be a source of a lean stumble during transition also!
This mod is one flat out fat big mistake to apply to the secondary side of a Q-jet! Sorry I can only draw a picture of what the mod looks like since I am not home a access my book I speak of.
The Following 2 Users Say Thank You to steve25 For This Useful Post: | ||
X2 on this statement
Here, this is what should not be done.
Solder them closed if you find this.
Yes...
JMO Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
