Old 11-09-2023, 08:54 PM
72projectbird's Avatar
Default 79 Trans Am resto
picked this 79 up earlier this year. I didn't get to it until recently, but now I'm making some headway.
It's a super solid car, numbers matching 403 auto car. Bought new in CT, spent some time in MA before making its way back to CT. Now I have it, and it's back in MA. I bought it in a million pieces, and roughly assembled it in the guys driveway to take it home. After sitting in the corner for a while, I got to work.
So far I've stripped the body, repaired the passenger lower quarter, and sprayed it BC/CC black. Got the rebuilt 403 back in, with all new brake lines, booster and master. I'm currently buttoning up the engine now in preparation for its first start and camshaft break in.
I'll be updating this thread as I go along.
ID:	623074   Click image for larger version
ID:	623075   Click image for larger version
ID:	623076   Click image for larger version
ID:	623077   Click image for larger version
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 11-09-2023, 08:56 PM
More pics
ID:	623079   Click image for larger version
ID:	623080   Click image for larger version
ID:	623081   Click image for larger version
ID:	623082   Click image for larger version
1987 Grand National
Old 11-09-2023, 08:59 PM
Pics 2
ID:	623084   Click image for larger version
ID:	623085   Click image for larger version
ID:	623086   Click image for larger version
ID:	623087   Click image for larger version
1987 Grand National
Old 11-09-2023, 11:44 PM
Wow great work...
Old 11-10-2023, 09:54 AM
Trevor78 Trevor78 is offline
Was that the water neck that came in the 79?
Old 11-10-2023, 11:43 AM
Wow great work...
Thank you!
Yes sir. It's original to the car.
1987 Grand National
Old 11-10-2023, 05:42 PM
Got the trans installed today. The lift was tied up, so I got to do it old-school on the floor with a jack. Went in pretty easily though. Also ran more hoses and wiring in the engine bay.
Does anyone know how the throttle return spring is supposed to go on this setup? Just glancing at it, I don't see where to hook it up.
ID:	623129   Click image for larger version
1987 Grand National
Old 11-10-2023, 07:48 PM
Return springs run from the idle-solenoid bracket hole, just out of shot, to that small tab with hole on the linkage.
http://forums.maxperformanceinc.com/...7&d=1699577937
Firebird 403 carb spring EGR quadrajet by Ben, on Flickr
The Following User Says Thank You to Trevor78 For This Useful Post:
Old 11-10-2023, 08:31 PM
Cool, thank you!
Since mine is a heat only setup, should I have the idle solenoid on my carb? I thought they were only on ac setups?
1987 Grand National
Old 11-11-2023, 04:14 PM
Chipping away. Got the driveshaft, speedo cable, vacuum modulator, battery cables, and tranny lines installed. The car has power running through it for the first time since 2007.
Now it's time to track down little electrical gremlins, like the turn signals not working, and the headlights not coming on. Oddly enough, the wipers and horn work, which is usually what I fight with to get working lol
1987 Grand National
Old 11-15-2023, 01:32 PM
Fighting with the pulley alignment. The ps pump needs to go back about 1/4" to line up with the second rib on the wp pulley. There's really no adjustment, and the ps pulley is pressed on all the way, so this should be fun to figure out.
1987 Grand National
Old 11-15-2023, 01:40 PM
Has that combination of pulleys, brackets and water pump been together before?
Old 11-15-2023, 05:45 PM
No idea, it was all in boxes when I got it. The crank pulley seems to be for a 77 and down Olds, but it lines up with the first 2 grooves on the water pump pulley after I spaced out the WP pulley for chits and giggles. I can get everything to line up with the WP pulley spaced out.
I wish I knew for sure what is throwing it off. The PS assembly looks right from the links provided and viewing the service manual. The alternator seems to be in the right place with the brackets set up correctly.
Idk. I don't mind spacing out the WP pulley if I have to, but it's not correct.
1987 Grand National
Old 11-15-2023, 06:03 PM
napster's Avatar
napster napster is offline
Was your T/A from Rudy Pontiac in Norwalk, CT? My family owed the dealership.
Jim
Old 11-15-2023, 06:52 PM
Jim
It came from Wile Motors in Willimantic CT.
The options were:
403 with Th400 trans
Hood decal
Body side moldings
White letter tires
Additional insulation
Front & rear floor mats
RH vanity mirror
Drip rails
Power windows
Super cooling radiator
Am/Fm cassette radio
Snowflake wheels 7"
Delay wipers
Not loaded up, but not totally stripped either. Oddly enough it has no rear defrost.
1987 Grand National
Old 11-16-2023, 04:57 PM
Well, the first start was a failure. Started pissing out coolant from the back of the intake manifold. So rather then fighting with that while trying to break in a camshaft, I'll be pulling the intake and resealing it.
Figures, I buttoned up the engine bay today. Got the radiator in, hoses, belts, fluids etc etc.
Oh well :/
ID:	623354   Click image for larger version
1987 Grand National
Old 11-17-2023, 12:53 PM
Yessir, that was the leak. Rear passenger side coolant passage was leaking like a sieve.
Oh well, at least it's not too big a deal to fix.
1987 Grand National
Old 11-17-2023, 10:52 PM
MDGOAT69's Avatar
MDGOAT69 MDGOAT69 is offline
Looking good!
1979 Trans Am: Y84 WS6 400/4spd
1967 YS 400, 670 heads, Summit 2802 cam, long tubes, ST-10 trans. McLeod hydraulic clutch conversion.
Old 11-18-2023, 05:13 PM
I'm having a hell of a time getting it to fire off.
I set cylinder #1 at TDC compression, distributor rotor facing #1, wires run 18436572 counter clockwise. I have spark at the cylinders verified by a spare plug put in each wire and cranked. Tons of fuel in the carb.
I'm not getting anything. Not even a cough. Even if the distributor was 180 out I'd get a fireball out the carb.
I must have pulled and set the distributor 20 times.
Do you guys think the valve timing is off? I'm setting it with both valves closed, but I'm running out of ideas.
I'm ready to pull the front of the engine apart and verify the cam installation.
Suggestions?
1987 Grand National
Old 11-18-2023, 05:45 PM
Shiny Shiny is offline
How do you set idle/static timing?
