Old 11-10-2023, 09:03 AM
79 Phoenix's Avatar
79 Phoenix 79 Phoenix is online now
Default Muncie M13 Gasket Set
Soon I will be removing the side cover and checking out my Muncie M13 HD 3 speed. Assuming all looks okay, I want to replace side cover gasket, front bearing retainer seal and rear tail shaft seal. I can't seem to find these parts, just M20, M21, M22 parts.
I can make the side cover gasket if need be.
But are the front and rear seals the same as for the 4 speeds?
Old 11-10-2023, 10:50 AM
i82much's Avatar
i82much i82much is offline
no idea but that is super cool that you are sticking with a three speed ... thought i read somewhere that a lot of times they were actually faster than the four speeds because you don't need four gears with a big engine that pulls like a tractor and you just waste a shift with a four speed ... and this is from a die-hard four speed guy!
Old 11-10-2023, 12:35 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
4spds don't use a front seal, so no they are not the same. Unless they don't use seal either.
one of the reasons they leak all the time. they use a oil slinger in front of front bearing.
64 Lemans hardtop
4spd, buckets
Old 11-10-2023, 12:45 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
I'm a fan of the M-13 myself. My fav daily driving trans in my fleet.
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
Old 11-10-2023, 03:44 PM
unruhjonny's Avatar
these guys are one of few go-to sources for 69-74 Muncie three speed "SM330" transmissions:
http://www.garagemotorsports.com/
1970 Formula 400
Old 11-10-2023, 04:00 PM
unruhjonny's Avatar
It is worth mentioning that some eBay sellers get the Muncie 318 & Muncie 330 mixed up;
If you're looking for gaskets, be sure that the side cover gasket is the correct one.
I believe the gasket set I got from Garage motorsports was a set cut from felpro gasket paper (not that there is anything wrong with that) - but old stock delco gaskets are out there.
One set that I bought came in an older delco style bag with the following printed on it:
G 318
3 SPEED HD MUNICE
GM PRODUCTS 1969 74
But they were absolutely the correct gaskets.
1970 Formula 400
Old 11-12-2023, 04:52 PM
79 Phoenix's Avatar
I'm going to take it apart and see if there is an O ring seal this week. Maybe it is the same as a 4 spd???
Old 11-12-2023, 05:01 PM
79 Phoenix's Avatar
Thanks for the link and the helpful info. This week I'm going to take the shift linkage off so I can see the side cover shape and bolt holes so I can make sure I get the right gaskets... Also do you remember if your M13 had an O ring behind front bearing retainer?
Old 11-13-2023, 06:17 PM
unruhjonny's Avatar
unless I am mistaken the front seal was a Saginaw thing;
These use a front bearing retainer similar to a Muncie four speed, in that the "seal" is the bearing retainer.
There is an oil slinger at the front bearing...
Now I am wanting to go look at the front bearing retainer that I changed (from truck to car) because I don't recall there being any pressed in seal on the retainer...
1970 Formula 400
Old 11-13-2023, 07:16 PM
unruhjonny's Avatar
I was wrong.
We have a seal;
It actually looks as though the seal used in the saginaw transmissions is the same one we use.
Group 4.354
Pt # 39879; supersedes #3761933 (Nov 1974 printing)
This is the "truck" bearing retainer I had replaced on my "A" gear set transmission - you can see the installed seal still in place:
1970 Formula 400
Old 11-13-2023, 07:32 PM
79 Phoenix's Avatar
Okay thanks for checking! I didn't get to taking mine apart--maybe tomorrow. But along with the link you gave me I also found these at rock Auto... O ring looks small but side cover may match up... visually anyway.
https://www.rockauto.com/en/moreinfo...choice=0-0-1-1
Old 11-13-2023, 07:45 PM
unruhjonny's Avatar
that is the wrong set.
That side cover looks to be a saginaw.
That same MPC I quoted earlier has the gasket set listed as:
Group 4.109 #3952621
Also, incase you never came across this thread before, it may be worth mentioning - HERE
1970 Formula 400
Old 11-14-2023, 11:54 AM
79 Phoenix's Avatar
Thanks for the link to that thread! No, I hadn't come across it. I am reaching out to the place (link) you sent me earlier and another place drivetrain.com to see if they can help with this. If need be, I can make a gasket for the side cover and I think I may have found a tail shaft seal (link below). So, althought I would like a whole gasket set, that bearing retainer o ring is all I really need (I think).
Hopefully, when I get this apart everything inside will look okay.
https://www.ebay.com/itm/293080558115
Old 11-14-2023, 11:56 AM
79 Phoenix's Avatar
Old 11-14-2023, 01:41 PM
unruhjonny's Avatar
from the same guys, here is a gasket set :
https://www.ebay.com/itm/35180797704...wAAOSwZVlXrNDU
(this actually confirms to me that the "fel pro" set I have was from them.)
Here is actually a kit that I bought from them:
https://www.ebay.com/itm/29241453283...kAAOSwXOhaYTLH
1970 Formula 400
Old 11-14-2023, 03:19 PM
79 Phoenix's Avatar
Thanks Jonny--Just called and ordered front o ring, side cover gasket and rear seal from The Garage. Really nice people and very knowledgeable, helpful and prices reasonable Thanks for steering me this way! Hopefully I won't need to talk to them again but I know where to go if I have issues inside. Thanks again!--Kim
The Following User Says Thank You to 79 Phoenix For This Useful Post:
