Old 11-28-2023, 09:15 PM
ckaram68's Avatar
ckaram68 ckaram68 is offline
Default Idle stop solenoid, W72
Hey all, looking for the above and seems it not available.
If I used an aftermarket or non-400 solenoid I'm guessing it works but checking if anyone has successfully done this.
Here's one listed for a 350 Pontiac, for example:
https://www.napaonline.com/en/p/CRB2...&ppid=CRB22187
My car is 78/W72/AC/4-speed
Old 11-28-2023, 09:41 PM
Trevor78 Trevor78 is offline
It only has to match the carb being using, to mount the bracket and have the plunger align so it can push idle up to adjusted setting.
The Following User Says Thank You to Trevor78 For This Useful Post:
Old 11-28-2023, 09:42 PM
bhill86's Avatar
bhill86 bhill86 is offline
I used one that was listed for a corvette I think. I just made some spacers to position it accordingly with plans to make a different bracket at some point.
1977 Trans Am 400/4speed (swap)
Brian
The Following User Says Thank You to bhill86 For This Useful Post:
Old 11-28-2023, 09:56 PM
ckaram68's Avatar
Cool. I see some without the bracket: https://www.napaonline.com/en/p/CRB2...ng_dcoe_google
I should be able to remove the original from the bracket and make the new solenoid work. Thanks!
Old 11-29-2023, 11:50 AM
burd burd is offline
I have 2 without the brackets. I have decals for them as well. I had mine produced
The Following User Says Thank You to burd For This Useful Post:
Old 11-30-2023, 01:53 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My 78 had a separate bracket and solenoid.
The separate solenoid fits the Holley carb bracket too!
Skip Fix
