Old 12-11-2023, 02:02 PM
Tim Corcoran's Avatar
Default Low 1st Gear TH-400
I know some people put a lower 1st gear in a TH-400 to get out of the hole faster. I understand how this would improve 60' times. Now with the lower 1st gear when you shift into 2nd you will have a larger RPM drop than you would with the standard 1st gear. Can someone explain how this will affect overall E.T.? Would the 1-2 shift pull the engine down and cancel out any gain in 60'?
Tim Corcoran
Old 12-11-2023, 02:11 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
I had a lower 1st gear in a TH400 the late Greg Merrick built. It was great while it lasted...BUT that planetary gearset (I believe from a TH200) is much weaker. My HFT cammed 463 did this to it.
Name:	tranny parts.jpg
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
The Following User Says Thank You to Johnny406 For This Useful Post:
Old 12-11-2023, 03:49 PM
cgeise's Avatar
cgeise cgeise is offline
depends on HP and converter.
Old 12-11-2023, 07:57 PM
Half-Inch Stud's Avatar
Non-stock 1st ratio is a Waste of money with 400+ CID, if ya gotta upshift before the 60foot
Old 12-11-2023, 10:49 PM
Formulas's Avatar
Formulas Formulas is offline
I dont have numbers in front of me and sometimes varies by manufacturer but i believe second gear is also lower.spreading out the RPM drops its not just on 1-2 shift
Also i believe the higher quality units have 5 planet gears, Hughes stands out in my memory as a better one
........... The More You Follow The Herd The Less You Can Be In The Lead ..........
Old 12-11-2023, 11:05 PM
beemergary's Avatar
When first gear is lower your second is also in my th400 and the pinions are square cut. Its makes alittle noise but not really noticed.
Old 12-20-2023, 11:23 AM
Stan Weiss's Avatar
Coan offers many different gear ratios for the T400
Rossler offers many different gear ratios for the T400 and also the 4L80E
Scott McClay offers many different gear ratios for the TH200
Stan
Pontiac Pump Gas List
Old 12-21-2023, 09:35 AM
grandville455's Avatar
grandville455 grandville455 is offline
I used a coan in my grandville years ago it was 5 pinion gear set and very strong! Those Tci ones are junk and weak, not sure what greg used above
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 12-30-2023, 01:36 PM
Steve Barcak's Avatar
Hey Tim,
Learned of these gear sets in the early 1980s and first used one on 72 GTO street/strip car. My first 11 second daily driver back then in 1985. I liked it and swore by them for 10 years or so but, as time went on, I now think it good for a heavy street car owner than does not want to use an OD trans. Otherwise, probably best not to use one on a dedicated bracket deal.
Have one today in a trans I purchased with a car. Not sure what I will use it in, maybe one of my station wagons.
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
