Old 12-14-2023, 03:21 PM
charlie66's Avatar
Default MSD 6530 box
Hi, is there anyone familiar with this box? I bought one and it wont let the engine run with it connected to the computer . It works to configure the tunes but after that i have to disconnect it to run the engine ..
Has anyone with this box ever experience this ?
My Half AN Injun.....
Old 12-15-2023, 04:42 AM
chuckies76ta's Avatar
MSD Programmable Digital 6AL-2 Ignition Box. Just verifying this is the correct box? I run this 6AL2 box on my wife's car and had to have the box powered up with 12 volts when programming it. I connected the computer to the box installed in the car and did not have this issue as I can remember. I just remember needing a special cable to connect the computer to the box. (USB to Serial port) I could try it again and verify it works. Your suppose to be able to monitor some parameters ( rpm, degrees, and map) while engine is running. So I can't see how it would not let engine run when connected. Another thing is there coil specific. This is probably not mush help to you.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
Old 12-15-2023, 08:44 PM
charlie66's Avatar
Thanks i appreciate your reply .
Its a 6AL-2 programmable box. I wound up sending the box back because it started not working even when not connected to the computer. Ill use my BTM box instead now .
