Old 12-21-2023, 07:41 PM
Cammer-6 Cammer-6 is offline
Default what are these?
looks like 2 different versions of same component.
most likely the newer one has the 2 piece pigtail and built in mount.
ID:	625406   Click image for larger version
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 12-21-2023, 09:46 PM
Some kind of rectifier?
(thing with fins is a heat sink?)
Old 12-21-2023, 10:29 PM
bill ryder's Avatar
bill ryder bill ryder is offline
Maybe an amplifier for a tape deck??
"Bill"!
The Following User Says Thank You to bill ryder For This Useful Post:
Old 12-22-2023, 05:03 PM
I believe I saw Delco stamped somewhere but will go back and look again
Old 12-23-2023, 04:22 PM
jmt455's Avatar
jmt455 jmt455 is offline
I believe you have a stereo heat sink for late 60's AC Delco stereo radios.
Some vehicles (1968 A body Pontiac, First-gen F body, Second-gen Corvette, etc.) used a remotely mounted amplifier.
Here's a picture of a similar (mono) heat sink. This one is for a 1967 Firebird AM-FM radio.
Name:	1957 Firebird AM-FM side view amplifier heat sink.jpg
"Keep your stick on the ice...and your head up."
1910 Buick Model 19 Touring
1923 Cadillac 5 passenger coupe
1933 Pontiac 4 door sedan project
1933 Sport Coupe project
1968 GTO, 428, THM400, 2.73 posi cruiser
1969 Chevrolet C10 Fleetside, 350, THM400
1958 Buick Caballero 4dr hdtp wagon
2018 Ram 1500 to tow stuff
2024 Buick Encore GX
Old 12-23-2023, 05:28 PM
that heat sink is common.
I have the 67-8 Firebird stereo and it uses nothing like this
Old 12-23-2023, 08:19 PM
george kujanski's Avatar
Early transistorized ignition? If not Delco than aftermarket? Some early stuff used transistors to switch the coil; the points were used to control the transistors... seems like too many wires for that purpose tho.
George
Old 12-24-2023, 11:06 AM
George
I have an NOS TI unit for sale and it looks nothing like this.
I think the key will be the wiring harness connector.
Old 12-24-2023, 11:11 AM
George heres what the TI control unit looks like
https://forums.maxperformanceinc.com...d.php?t=868017
Old 12-24-2023, 12:07 PM
stellar stellar is offline
Do you have an electric scooter? Possibly a control unit for that. Also possibly a rectifier regulator for a boat or motorcycle, but usually there will be 3 wires of the same color and a different type of plug.
Old 12-24-2023, 02:19 PM
I recall seeing an aftermarket "transistorized ignition" unit back in the day built on a similar heat sink, and also recall only a single transistor, kind of the stuff you would find in the JC Whitney catalog.
George
Old 12-24-2023, 05:31 PM
Our 63 GP had TI and something flaked out on it so Dad built a Heathkit unit and ran with that.
Im certain this isnt that.
