Old 01-11-2024, 03:31 PM
ejgoat ejgoat is offline
Default 1964 grille
What color is the grill insert on a 64 goat grille, would it be satin black
Old 01-11-2024, 04:28 PM
Dick Boneske's Avatar
I use Rust-O-Leum #7777 or the SEM Trim Black. The SEM product is easier to work with, and I've had good luck with adherence. I noticed it is available from WalMart online at $13.62.
Masking the unpainted areas takes a lot of time, but pays off.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 01-15-2024, 01:11 AM
giles's Avatar
giles giles is offline
I used the Rustoleum Satin black. And yes it takes hours to mask. But then masking a Tempest / Lemans is harder than a GTO.
Old 01-15-2024, 02:24 AM
I removed what was left of the paint on my Tempest grilles for a different look.
I’m doing it on my Le Mans as well, I like the look of the bright grille bars and surrounds.
Of course I can always paint them later if I think it will look better.
Old 01-15-2024, 01:06 PM
bill ryder's Avatar
bill ryder bill ryder is offline
I use the thin 3/16" pin stripe tape for the initial taping. It bends a lot easier on the radiuses. Then go with your wider masking tape, whatever brand you like. Like Dick said, take your time masking. The painting is the easy part!!
"Bill"!
Old 01-21-2024, 02:16 AM
giles's Avatar
As long as we are talking grilles. I have an observation and maybe the ‘64 brain trust has already seen this. My ‘64 Tempest (10C build date) was crashed in the RF corner very early in its life, like within the first 6 months. I believe one grille is original and one was replaced when repaired. One grille has a riveted vertical reinforcement brace on the back side and one does not. Has anyone observed this before?
Old 01-21-2024, 10:37 AM
Rich-Tripower's Avatar
Both of my grills have the vertical support riveted in. At this point I really have no idea if they are the originals to the car but if I had to guess I'd say they are. Car was built in July 1964.
Old 01-21-2024, 11:20 AM
bill ryder's Avatar
I have seen GTOs with both riveted and non riveted grills. I have been fortunate to have judged 64s at POCI and GTOAA for A LONG TIME. That question has come up several times. Some opinions are both pro and con. I have never seen anything in writing to confirm or deny. My personal thought is a production change early in the 64 build year. No reason to build two different grills otherwise the same.
Maybe an answer will come forth in this thread!!
"Bill"!
Old 01-22-2024, 10:16 AM
Which is why I added the build date of our car to my post. As stated, mostly likely a mid-year change. Now the question is, when did the change occur? It may be hard to determine as there are so few cars out there with their original parts still with the car and known to be so.
Old 01-22-2024, 12:01 PM
bill ryder's Avatar
Exactly, Rich. Maybe some of the 64 owners will check their grills and post here...
"Bill"!
Old 01-22-2024, 01:00 PM
GtoFM's Avatar
GtoFM GtoFM is offline
My ‘64 has the riveted support. 06B build date, Pontiac plant. It could be production change or just different suppliers.
Old 01-23-2024, 06:02 PM
The Champ's Avatar
Mine is an April '64 build and the one's on the car when I bought it did not have the brace. I replaced the original set with a much better set, which did not have that support. I do have one other set without the support also.
Old 01-23-2024, 07:02 PM
bill ryder's Avatar
Interesting. Mine is first week, April, Pontiac, and does have the support, rivets...
"Bill"!
