It may ground the same way …( if it’s even required .) this pic is from my 73 before I put in the radio delete plate and I don’t recall if there was a ground wire attached to that metal bracing the support bracket attaches to….thats part of the dash… check that brace on the dash see if a grd on it….from what I remember the dash itself grounds via the attaching bolts I believe to the body….
![](image.php?u=143620&type=sigpic&dateline=1706230098) 1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
