Hi Guys does anyone know what these 2 connectors went too ? Thanks
They are near the fuse panel area
Wish I could help ya.
Those may actually go to the fuse box, but where I can’t say. You can look close at the male spades in the fuse box and see where two of them are shinny like there was once one of those connectors on them. Since the box is labeled you may be able to ring out where at least one of those unplugged ones go, and from there it just a process of elimination for the other one. The good thing is those two look like they do not have anything to do with the engine cranking or running.
I’m finding the brown wire(s) one listed as accessory feed but I’m admittedly not familiar with its purpose. The green one I’m not finding as of yet and don’t recall seeing it on my 77
1977 Trans Am 400/4speed (swap) Brian |
Thanks guys , yea the car starts I was just trying to sort the wiring under the dash and found those would just like to know …
Maybe if I find where they go , I will gain 50 more HP …😂
If you don't have any know problems, probably just wire connectors for some accessory that you don't have? Lots of time the factory loom has the connectors wrapped since they aren't used.
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
I can say, with regard to the brown ones, one brown wire comes from the fuse box and goes to that clear connector then from the connector to power the blower motor resistor. The connector may not be used on f bodies. I tried helping another guy on a different forum with an electrical issue and these two wires/connectors your posted came up. I wasn’t able to figure out the green aside from possibly the front speaker but I’m not sure that’s accurate.
I saw a lt. green for the back-up light and one for a rear window defrost or defog.
You might be on to something with rear window defogger. That green wire should be near the fuse box I believe.
I could be wrong (it's been nearly thirty five years) but I think the green wire is for pulse wipers.
Thanks guys ,
