Old 01-24-2024, 07:14 PM
cnc's Avatar
cnc cnc is offline
Default Stripe kit
So I wanna install my 70-72 stripe package on the car this winter heated garage ….the car was painted 2 years ago bc/cc they also told me they put couple coats wax on it when it was done painting,,,,since it been two years and most of that time the car sat in my garage ..is there anything I should do to PREP the paint surface before applying the stripe kit…and what about garage temp for applying…..just wondering…thanks in advance ….Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 01-24-2024, 07:44 PM
JSuchma JSuchma is offline
My job includes applying decals for dealerships and body shops. That said, use a wax and grease remover on the areas where the decals will go. As for temperature, 70 to 90 degrees is the best temperature range.
Old 01-24-2024, 07:48 PM
cnc's Avatar
cnc cnc is offline
Thanks for the reply….Suggestions for wax grease remover name brand,don’t want to damage the newer paint…
Old 01-24-2024, 08:02 PM
Any brand will do. No need to buy PPG. Usually, the local auto parts stores carry QT. cans of it. Don't worry about the paint as it is mild and your paint has cured for 2 years.
Old 01-24-2024, 08:20 PM
cnc's Avatar
cnc cnc is offline
Ok thanks for the heads up…
Old 01-25-2024, 12:46 AM
MUSLCAH MUSLCAH is offline
Glass cleaner will clean those areas ...where the stripes go.
There is a solution that is applied to the Decal as well as the panel.
If the panel is cool....you can warm it up with a heat gun.
Old 01-25-2024, 12:49 AM
Old 01-25-2024, 07:26 AM
cnc's Avatar
cnc cnc is offline
Glass cleaner eh...like full strength windex???? Or like Invisible glass from Costco...????
Temps won't be an issue house furnace out in the garage... yes soapy water mix to apply the decals and there is a solution u can also purchase
Old 01-25-2024, 10:34 AM
Correct, glass cleaner will work but I carry wax and grease remover with me because I don't know what I will run into from job to job. As for the application, I have tried everything on the market, and I prefer Johnson baby shampoo mixed with water. I use about 2 tablespoons to a quart of water.
Old 01-25-2024, 10:41 AM
78w72 78w72 is offline
Dawn dish detergent works great to remove wax/grease too, can spray a diluted mixture from a spray bottle just like glass cleaner... but can also use a drop or 2 of dawn detergent in a spray bottle to apply the decals too, i found it works much better than the thick gel.
What color stripe are you using on your car? Is the car still orange like in the pic?
Old 01-25-2024, 02:14 PM
Cammer-6 Cammer-6 is offline
Rapid Tac for the win.
They also offer rapid prep and rapid remover.
https://www.jbtools.com/rapid-tac-ta...0aAuc2EALw_wcB
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 01-25-2024, 08:40 PM
cnc's Avatar
cnc cnc is offline
This is the kit and yep still orange( think u asked me in another post lol) it’s actually Tangerine orange. Subaru Color…that attached pic was something we Just chose a trans am and changed the Color to an orange of what we could get and I just use it for reference….until I get them on ….
Ok so looks like a few options out there….thanks for the help everyone
I changed my sig pic
The Following 2 Users Say Thank You to cnc For This Useful Post:
Old 01-26-2024, 10:34 AM
Looks great! Yeah i recall asking about that before now that you mention it.
