Old 01-27-2024, 03:41 PM
crm318 crm318 is offline
Default 1970 400 Factory Plug Wire Loom Locations
I just bought a set of 1970 plug wire looms for my GTO. I was wondering if anyone had any pics or diagrams of how these bolt to the heads.
1970 GTO: Atoll Blue, TH400, 400 +.060, small chamber Ferrea big valve fitted # 15 heads, Summit 2802 cam, Iron intake, Cliff Ruffles 850 cfm qjet, Hooker headers, 2.5 mandrel bent exhaust, Race Pro mufflers, 3.73 Safe-T-Track.
Old 01-27-2024, 04:25 PM
steve25 steve25 is offline
This highlighted photo should get you started.
Each of the two tall ones carrying 4 wires goes on the intake manifold side of the at the rear..
The ones carrying just two wires go under the front lower valve cover bolt.
You should be able to figure out the other ones after those are on.
Old 01-28-2024, 02:36 PM
KGTO's Avatar
KGTO KGTO is offline
The AC looms are different. Does your car have AC? I had to use the 69 AC looms and the one for #1 & #3 is different than what 1970 used.
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
The Following User Says Thank You to KGTO For This Useful Post:
Old 01-28-2024, 04:54 PM
Got them installed and the look great! I have Vintage Air, so the compressor wasn't really in the way.
