Is a 69-72 Grand Prix the same length as a 68-72 GTO ?
End to end of shaft
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
Yes. At least for 1970.
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
| The Following User Says Thank You to johnta1 For This Useful Post: | ||
So, is 55.34 center to center of the u-joint
I believe so.
Nice chart! Have F bodies on it? My 78 TA is about 48.5" Just remember also the front yoke can change that dimension. A stock trans yoke and a TH 400 measured different than the MW yoke did.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Good info John, thanks.
Now how far should the yoke be sticking out of the tranny ?
Bottom out the yoke and pull it back by 1” then measure with the car’s full weight on the suspension.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following User Says Thank You to b-man For This Useful Post: | ||
70 Bird chart:
John,
Is this chart straight out of the dealer's parts department book?? If so, do you know the year of the book? |
It's out of the 1970 service manual.
The 1978 didn't have the lengths. It did have the pinion angles and stuff. (also the 1972 didn't have it I think) I haven't looked at the parts book, yet.
All good info. Now I'm looking to have a new driveshaft made. Any recommendations ?
