Old 02-09-2024, 07:00 PM
caddor38 caddor38 is offline
Default transmission leak at driveshaft seal
Guys I have looked this up on a few forums, however I am not sure if this is the same problem. I have transmission leak around the outer seal of my th400 transmission. The leak is not where the yoke of the drive shaft slides inthe transmission but the outside perimeter of where the seal meets the th400 rear housing.. I have included a picture for a better reference. This is a new build and only 100 miles on this set up. Any idesa on how to fix this?
Old 02-09-2024, 07:30 PM
cnc's Avatar
cnc cnc is offline
Permatex flange sealer. U smear a light film of it around the outer surface of the metal face of seal that get pushed into the tail stock…….helps seal any small voids
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
The Following 4 Users Say Thank You to cnc For This Useful Post:
Old 02-09-2024, 07:31 PM
694.1 694.1 is offline
What he said.
Still have my 1st Firebird
7th Firebird
57 Starchief
The Following User Says Thank You to 694.1 For This Useful Post:
Old 02-09-2024, 07:47 PM
Oh, okay, i will give that a shot. Big thanks!
Old 02-09-2024, 08:52 PM
I do that with all seals of that type actually. It not only insures the sealing action but lubes it a bit for easier installation.
Old 02-09-2024, 09:55 PM
1968GTO421's Avatar
This looks to be something I've really needed in my garage for sometime. Appreciate the advice.
https://www.permatex.com/products/ga...sealant-50-ml/
GTOAA--https://www.gtoaa.org/
The Following User Says Thank You to 1968GTO421 For This Useful Post:
Old 02-09-2024, 10:29 PM
JLMounce JLMounce is offline
Yup, had to do that on my old TH400 as well. Have to remove the seal, smear the flange with sealer, and reinstall. Over time the finish on the bore degrades from corrosion and seal replacement. The seal itself just doesn't seal as well as it once did when the transmission tail housing was new.
-Jason
1969 Pontiac Firebird
Old 02-10-2024, 05:03 AM
Tim Corcoran's Avatar
I never install a seal like that dry, I normally use silicone but the Permatex flange seal may be better suited. I also lightly sand the mating surface of the seal. I do the same when installing freeze plugs.
Tim Corcoran
Old 02-10-2024, 09:52 AM
rohrt rohrt is offline
Today I learned....
Good stuff
Old 02-10-2024, 10:37 AM
Formulas's Avatar
Formulas Formulas is offline
I usually use a thin application of permatex #2 on the id and od of seals like that..... the exact product matters less than the fact of using something at all
........... The More You Follow The Herd The Less You Can Be In The Lead ..........
Old 02-10-2024, 11:56 AM
67drake's Avatar
67drake 67drake is offline
Timely, as the crankshaft seal on the Ford I’m building right now is almost identical. Wondering how I was going to get that in the aluminum cover, and have it seal up,as it was a royal PIA to get the old one out.
‘55 Catalina
Old 02-10-2024, 01:33 PM
67drake's Avatar
Couldn’t find anything specifically marked “flange sealer” from Permatex. Is this it?
Says good for aluminum and cast iron flanges
‘55 Catalina
Old 02-10-2024, 04:39 PM
VCho455's Avatar
VCho455 VCho455 is offline
Anaerobic sealers work good in this application
Old 02-10-2024, 06:06 PM
67drake's Avatar
After I posted that I Googled and did find the specific flange sealer being discussed, but my local place doesn’t have it. I’ll use the stuff I pictured rather than drive to the next closest store-50 mile trip.
‘55 Catalina
Old 02-11-2024, 12:12 AM
That should be fine.
Old 02-11-2024, 11:05 AM
cnc's Avatar
cnc cnc is offline
Yep
The Following User Says Thank You to cnc For This Useful Post:
Old 02-11-2024, 04:16 PM
GtoFM's Avatar
GtoFM GtoFM is offline
https://www.amazon.com/s?k=permatex+..._ts-doa-p_1_15
Amazon has everything....almost.
Old 02-11-2024, 06:46 PM
Wow... they're proud of that stuff!
