Old 02-17-2024, 09:16 PM
importsmasher's Avatar
importsmasher importsmasher is offline
Default Hood scoop insert paint question
My 66 GTO has been repainted a couple of times over the years (first time in 1988 when I was in high school), and I didn't realize that part of the hood scoop insert is supposed to be black. Can someone tell me if it's flat black, gloss or semi gloss?
Thanks,
Importsmasher
Scott Baggiore
66 GTO convertible 389/4 speed (parents bought new)
73 Firebird Formula 400/4 speed
74 GTO 455/4 speed
74 Grand Am
Old 02-18-2024, 10:11 AM
Keith Seymore's Avatar
Not gloss.
I can't decide between semi, flat or matte. I never can tell.
Edit: I just walked out and looked; would say not flat, either.
K
Name:	GTO Ram Air scoop.jpg
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
The Following User Says Thank You to Keith Seymore For This Useful Post:
Old 02-18-2024, 11:00 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Agree this black is NOT gloss or flat.
I say it’s the term seen often on these cars ….. 60 degree black or semi black.
The most important thing on the 65,66,67 hood scoop is the black in the inner ribs.
Drives me nuts that so many of these repainted cars people do not go back and paint the black.
ID:	628839   Click image for larger version
The Following User Says Thank You to 60sstuff For This Useful Post:
Old 02-18-2024, 11:04 AM
Yes, that is exactly why I'm asking. I didn't realize it was supposed to be black, and now I want to paint it. I'll do semi gloss.
Thanks for the input!
Importsmasher
Scott Baggiore
74 GTO 455/4 speed
74 Grand Am
The Following User Says Thank You to importsmasher For This Useful Post:
Old 02-19-2024, 02:26 PM
Nice photo of the Ruth Boehm '66:
Name:	Hood Scoop Ruth Boehm 66 GTO.JPG
'63 Grand Prix
The Following 2 Users Say Thank You to Keith Seymore For This Useful Post:
Old 02-19-2024, 05:20 PM
Sloan66's Avatar
Sloan66 Sloan66 is offline
Default How?
Any info on how the factory painted the insert? Was it done after body color or prior? Try to wrap my mind around mass production and details like this one.
Old 02-19-2024, 06:53 PM
60sstuff's Avatar
Kevin,
Good question.
I painted the black on a few back in the 80’s and it was a little time consuming.
Old 02-19-2024, 07:19 PM
GTO.PAUL GTO.PAUL is offline
Default Hood Scoop
I have a NOS scoop and can add some pics when I next get a chance for that. It is red oxide primer with the scoop "Air Inlet" section already blacked out. Paul
The Following User Says Thank You to GTO.PAUL For This Useful Post:
Old 02-19-2024, 07:26 PM
This seems reasonable to me.
I would suggest they painted the black first, then masked the black (using a reusable mylar or aluminum shield) to paint body color over the top.
We did some vehicle two tones that way, where the center (inset) secondary color was painted first, taped over, and then the primary body color painted.
K
'63 Grand Prix
Old 02-19-2024, 10:13 PM
Body colored inserts just scream repaint.
The Following 2 Users Say Thank You to Greg Reid For This Useful Post:
Old 02-19-2024, 11:39 PM
242177P's Avatar
242177P 242177P is offline
[wiseguy] Whattabout the ones painted Starlight Black? [/wiseguy]
Pls don't kill me, still needs less gloss
Old 02-20-2024, 05:11 AM
Well yeah, Starlight doesn't 'scream' repaint...just whispers it.. lol
Old 02-20-2024, 10:39 PM
Ducks Goat's Avatar
Ducks Goat Ducks Goat is offline
My original paint ‘67 for comparison.
1999 WS6 Formula, 1 of 175
1967 GTO Linden Green 4 spd, A/C, survivor
1967 Lemans convt
1967 Firebird 400 bench seat, deluxe interior, auto
1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, 7.159@95.33 (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne.
1961 Catalina 2 door htp
1960 Ventura 4 door htp wife's car
1960 B'ville 2 door htp
1960 Catalina Wagon wife's car too
The Following 3 Users Say Thank You to Ducks Goat For This Useful Post:
Old 03-02-2024, 04:59 PM
60sstuff's Avatar
Default Found it.
I knew I had one showing the paint process.
Factory red oxide primer that someone was prepping for a color.
Obviously the semi gloss Black was applied first.
I would assume some type of a firm mask was temporarily pushed into the inner ribbed portion and then body color was applied.
ID:	629701   Click image for larger version
ID:	629702   Click image for larger version
ID:	629703   Click image for larger version
ID:	629704   Click image for larger version
The Following 4 Users Say Thank You to 60sstuff For This Useful Post:
Old 03-02-2024, 11:14 PM
400 4spd.'s Avatar
For mass production it would be faster/cheaper to paint black and then block off the openings for body color application, than to apply body color and later mask the openings for black out.
The Following User Says Thank You to 400 4spd. For This Useful Post:
Old 03-03-2024, 02:06 PM
Default Hood Scoop
Here are the pics from the NOS '65-'67 GTO hood scoop I have. Was it all in primer and then the black was sprayed in the scoop area with some kind of mask on the outside or was the black sprayed into the scoop (no primer under the black) and then a mask was placed into the scoop and the primer applied to the outside? From here I can believe that a mask was placed into the scoop area and the body color was applied over the primer. Just had to make sure the mask in the scoop was not covering any primer on the edges of the scoop opening or one would end up with body color, then a primer line and finally the black scoop. Who was there to know for sure? Paul
ID:	629733   Click image for larger version
ID:	629734   Click image for larger version
Old 03-03-2024, 07:06 PM
bill ryder's Avatar
bill ryder bill ryder is offline
Just like covering the chrome valve covers and painting the engine. Every now and then, a little overspray on the chrome. Definitely a line on the dip stick bracket between the bolt and the dip stick. Who was there to know for sure?
"Bill"!
Old 03-03-2024, 08:00 PM
60sstuff's Avatar
This photo of Ducks says a lot.
Red primer showing through the black.
