EFI Tech All things EFI and making classics modern!
Old 02-18-2024, 11:36 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
Default Holley Sniper Stealth install on a '69 GTO
Just sharing some pics and a quick story of a modest upgrade I made on my '69 GTO recently. I bought a new-to-me/ virtually new Sniper Stealth system here on the forums last spring, and it sat in a box for a while until I had a chance to install it.
One thing that I didn't plan for was replacing the intake. I wasn't planning on swapping this, but once I realized my FI wasn't a spread bore layout that became a necessity. My engine is stock so I opted for the Edelbrock performer due to it being readily available. I ground down the divider some on the intake to help open it up as I understand these FI units work better with an open plenum design. Using this intake I had to trim the AC bracket down to fit.
I also modified the original throttle cable to work on this. I had a leftover threaded Lokar adjustment sleeve and was able to add this to the original cable by cutting off the end, drilling the tube portion out and using some aluminum brazing rod to melt the cable back inside. Seems to work well.
I also replaced the tank with the Tanks, inc. unit with internal baffles and installed that, as well as an adjustable regulator in back, and bent a new metal line up front
After getting everything assembled I had to upgrade the software in both the controller and the FI unit itself to be able to add the basic tune, and then I was able to start the car. It ran OK but the self tuning feature didn't seem to work too well. I'd get popping, back firing, adn the air/fuel ratio would go from 9 .55 to 35.99 and back n forth. When I got it tuned they told me the O2 sensor was bad, despite it being new. They disabled it in the tune so I don't even need to replace it now. I suppose if I ever modify the engine I'll need to go back to them for a retune, but for now it's working well.
If you add a system like this getting a proper tune is a must. I would recommend one in person where they can adjust on site either by driving or by using a dyno. I've had a few aftermarket FI systems now and in every instance it's a night and day better running car after being properly tuned.
I do notice an improvement in overall drivability, and better fuel economy, too. TBH my carb cold started OK, and the engine ran OK even when cold, but it had a terrible delay in the mid range throttle or when trying to open the secondaries and just made driving the car not nearly as much fun as it should be.
Hopefully these pics and story will be of help for anyone considering this.
ID:	628887   Click image for larger version
ID:	628888   Click image for larger version
ID:	628889   Click image for larger version
ID:	628890   Click image for larger version
Long live the Muscle Car
Instagram @tuske427
1967 Firebird #BVbird
1967 Firebird 400 4 speed project
1969 Verdoro green GTO (daily)
The Following User Says Thank You to Tuske427 For This Useful Post:
Old 02-18-2024, 11:43 PM
Tuske427's Avatar
more pics of the install and the tuning. there's a base tune pic that the air/ fuel ratio (red dotted line) is up/ down like a sign wave. not good. the car would surge and as mentioned ran poorly. afterwards it's much better all around.
ID:	628892   Click image for larger version
ID:	628893   Click image for larger version
ID:	628894   Click image for larger version
ID:	628895   Click image for larger version
Instagram @tuske427
Old 05-30-2024, 11:02 AM
Formula8's Avatar
Formula8 Formula8 is offline
I have the same system on my car. I was fuel only and it worked fine. I added spark control, had a few minor issues with that but built a basic timing map and have not done much with it since. I went through one O2 sensor but installed a spacer to take the sensor back out of the path of cold start condensation water and have not had a problem this year but I hear the O2 sensor and coolant sensors are problematic and we probably should keep a spare of each on hand. Plugs are clean and the fuel economy has really improved. I need to work with my start up tune as the engine turns over quite a bit to start the car. Probably off to a professional to tune at that point.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 05-30-2024, 07:10 PM
krisr's Avatar
krisr krisr is offline
Nice work! I always tell everyone, fuel control is a small part of the system. Spark control is where most of the gains can be had. My high compression 389 in my 66 is the worst when it comes to challenging to run on todays fuels but with the accuracy of how EFI computers do spark control, I can time everywhere to get the absolute best MBT out of it and not rattle its brains out once. My old carby/distributor combinations truly sucked until this one. Enjoy it.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120
'66 Pontiac GTO - 389, 4 speed street cruiser
