Old 02-22-2024, 09:42 AM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Default Clevite or Federal Mogul Bearings?
I pulled out the 463 for routine maintenance and inspection. My bearings are showing a little wear from racing and occasional nitrous use. The crank looks great but I'll measure everything today.
With that said, the motor currently has Clevite bearings in it -.010 crank and -.020 rod. Looking on Butler, they are twice the price as the FM bearings. KRE doesn't even list Clevite bearings, only FM. Is there a quality difference between the two to justify the price difference?
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
The Following User Says Thank You to Johnny406 For This Useful Post:
Old 02-22-2024, 07:05 PM
mgarblik mgarblik is offline
When FM moved all their bearing production to Mexico, the oil clearances were not as consistent as the older USA production. I like the design, 3/4 groove and thrust faces of the FM bearings however. In the last 8-10 years I have been using King bearings because of their quality and consistent oil clearances.
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
Old 02-23-2024, 02:01 PM
steve25 steve25 is offline
Another consideration for any bearing how hard it’s surface layer is which is a factor in allowing dirt to embed in the bearing and not chew up the journal it’s rotating on.
Old 02-23-2024, 02:48 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
So how many of you all redrill the main oil hole to match the block?
Skip Fix
The Following 3 Users Say Thank You to Skip Fix For This Useful Post:
Old 02-23-2024, 03:39 PM
I do, and I also open up the Vee groove that passes the oil from the block oil passage into the hole that feeds the bearings.
The area of that Vee groove formed by the factory drilling process is less then the oil passage hole.
Old 02-24-2024, 03:11 PM
Johnny406's Avatar
Do you have a picture of this?
Old 02-24-2024, 09:27 PM
AG's Avatar
AG AG is offline
I always do that since it's easy and free.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
The Following User Says Thank You to AG For This Useful Post:
Old 02-25-2024, 07:57 AM
John I do not currently have a block apart, but I found this picture.
Look at the thrust bearing oil feed hole and you will see how the Vee groove is a restriction.
You will need a 1/4” Ball head burr to grind it out.
Old 02-25-2024, 11:01 AM
Skip Fix's Avatar
I always do it also. Ever wonder why the bearing companies don't locate it in the best spot to begin with?
Skip Fix
Old 02-25-2024, 12:36 PM
Johnny406's Avatar
Just to make sure I understand, I want to open/clean this up a little bit, correct?
Old 02-25-2024, 06:28 PM
Correct!
It needs to ground out to a bit bigger the the oil passage that feeds it off of the main galley from the filter return.
Old 02-26-2024, 04:20 PM
tooski tooski is offline
Default Oil feed
Correct!
Steve, does that mean that the figure 8 ends up looking more like an oval, or is the v groove just ground down deeper.?
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 02-26-2024, 06:32 PM
Turn the V into a tall and bit wider U in other words.
The Following 3 Users Say Thank You to steve25 For This Useful Post:
Old 02-29-2024, 02:34 PM
mysticmissle's Avatar
Ia2a oil holes just for reference
FM .010 bearing will be opened up to help flow
But I wouldn’t loose sleep over it the area of the slot is probably more then large enough to compensate for the obstruction
ID:	629559   Click image for larger version
ID:	629560   Click image for larger version
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 02-29-2024, 02:40 PM
Skip Fix's Avatar
And the IA2A has an oil hole through the front main stud for an accessory feed like a turbo.
Skip Fix
Old 02-29-2024, 02:48 PM
Yes I haven’t looked at an iron ia2 yet but o don’t think the oil passes thru the stud on an iron ia2 curious why I assume strength and desire to leave extra material
In the area same reason the outer
main fasteners are studs and not bolts
1964 540 gto
Old 02-29-2024, 08:15 PM
Johnny406's Avatar
How's this? I didn't want to overdue it.
Name:	block oil mod1.jpg
ID:	629580   Click image for larger version
Name:	block oil mod2.jpg
Old 02-29-2024, 08:27 PM
Looks good to me
1964 540 gto
Old 03-01-2024, 06:50 AM
Looks fine.
Old 03-01-2024, 08:55 AM
Default Mod bearings
Need to dress a bit more w a round file but you get the idea
ID:	629612   Click image for larger version
ID:	629613   Click image for larger version
1964 540 gto
