Old 02-25-2024, 06:50 PM
grd777 grd777 is offline
Default wtb a 72 defogg switch connector
looking to but the correct 4 prong connector (off a old used harness) for a rear defrost switch on my 72 formula
Old 02-26-2024, 03:50 PM
Formulabruce's Avatar
Should be made into the harness as this was Not a dealer installed option. Connector may be used on both type of rear defrost/ defogger, soooo. All terminals may not get used.
" Long may we DRIVE !"
Old 02-27-2024, 07:01 PM
For somereason I think mine is missing or cut off how does it look like
Old 02-27-2024, 10:40 PM
Held for Ransom's Avatar
Here is '73...
ID:	629471   Click image for larger version
So long, farewell.
Old 02-28-2024, 12:48 AM
Here is '73...
Looks like on of the prongs on the switch is not being used. Does the connector only have 3 prongs
Old 02-28-2024, 07:02 AM
Again, this is 1973, but I think the switch is 1972. Connector had only three wires (labeled A B C on plug). 1972 looks like the Brown wire was Pink. I don't know what goes on the fourth terminal.
So long, farewell.
Old 02-28-2024, 07:13 AM
I would say that is a ground connection along with the item in the lower left has a ground connection.
Old 02-28-2024, 07:42 AM
Ok I found this connector ,so do need to find a ground wire now
Old 03-01-2024, 12:46 AM
Ground is in that harness on the connector. The connector fits BOTH styles of rear defrost/defog switches.
Old 03-01-2024, 08:01 AM
ok so the prong the photo is not used
Old 03-01-2024, 04:11 PM
Correct
Old 03-01-2024, 04:13 PM
Correct
thank you for this info
