Old 03-04-2024, 04:16 PM
Coact Coact is offline
Default headers size for 68 Firebird
What size headers would be required to support a 750 hp engine? Round port.
Looking at a set of Doug's 1-7/8" for a 68 Firebird.
Also wondering if they will fit a 68 Firebird?
Old 03-04-2024, 05:09 PM
PAUL K's Avatar
PAUL K PAUL K is offline
This might be helpful
https://forums.maxperformanceinc.com...errerid=134156
Go fast, see Elvis!
Old 03-04-2024, 05:20 PM
Steve C. Steve C. is offline
Posted for conversation...
https://www.motortrend.com/how-to/he...s-performance/
Note on the graph it states "inside" diameter. Take note of the tubing used on the headers involved, are they based on a popular 16 gauge or 18 gauge materiel.
Example if 16 gauge: .062" thick x 2 sides = 0.124"
Old information here:
Old 03-04-2024, 07:22 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Paul would larger headers mask a poor cam selection?
Meaning, if the cam is not correctly spec'd would larger headers add more power.
Old 03-04-2024, 08:28 PM
AG's Avatar
AG AG is offline
I use 2" tubes on my car at around 700 Hp.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 03-04-2024, 08:30 PM
steve25 steve25 is offline
Handy chart.
Old 03-04-2024, 10:17 PM
The handy chart above, again based on the inside diameter.
Old 03-05-2024, 08:58 AM
PAUL K's Avatar
Hi John..... No, I don't think so.
Go fast, see Elvis!
Old 03-05-2024, 01:15 PM
chiefbigb chiefbigb is offline
I believe 1 7/8 would work fine. I used a set of Doug's recently and had to clearance them on the idler arm and power steering box . These were round ports. The mad dog headers fit well I hear if you can get a set.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 03-05-2024, 01:49 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
We tried some 1 3/4-1 7/8 step-real short 1 3/4 section and about as big as port on a friend's 650 HP 462 E head roller motor and lost 40 HP and a lot of TQ vs the 2" he had. Used some modified GTO Hookers to fit his 63 Tempest.
Skip Fix
