Old 03-06-2024, 08:54 AM
ddcrank ddcrank is offline
Default 70 Power disc part numbers
Need help figuring out part numbers for a 70. My car was built the 4th week of October 69. Can someone help with part numbers for calipers and a master cylinder code for power front disc. Not sure if they used the 69 calipers on the early cars or not. I'm pretty sure they did not use the round master cylinder type on any of the 70 models but again there are members here than have more knowledge about this than me.
Dan
Old 03-06-2024, 12:33 PM
gto4ben gto4ben is online now
Master Cylinder Codes
Name:	68-70 Master Cylinder Usage.jpg
The Following User Says Thank You to gto4ben For This Useful Post:
Old 03-06-2024, 01:58 PM
Thank you for that list. That helps alot. Do you have any info on the disc calipers as far as part numbers?
Old 03-08-2024, 11:04 AM
Can u post that info for 71-72 fb & tempest ?
Old 03-09-2024, 04:07 AM
The 71 and 72 Pontiac shop manuals do not have the master cylinder codes listed like the previous years. If the '71-'72 application requires the power disc Delco-Moraine master cylinder, the Pontiac Master Parts Catalog lists 5471802 for all A,B,& G power disc Moraine. This number is also in the Oldsmobile MPC for the F85 & has a stamped code of "BE".
