Old 03-06-2024, 05:12 PM
george kujanski's Avatar
george kujanski george kujanski is online now
Default a kind of buzz vibration felt in the steering wheel
not a Pontiac....A caddy Allante, rack and pinion, straight ahead not bad, gets more noticeable when turning wheel slightly.
Plenty of fluid... this seem like a pump or rack issue? changing rack on this thing is a real pain...rather diagnose the issue before doing R&R
Thanks for any suggestions.
george
Old 03-06-2024, 05:36 PM
steve25 steve25 is offline
Are there bubbles in the fluid?
You may have a return hose sucking air.
Old 03-06-2024, 09:38 PM
max 93 max 93 is online now
Could it be a wheel bearing? I had a slight vibration that could be felt in the steering wheel on a 4th gen trans am. Could only notice it on gentle turns. It was a damaged wheel hub.
Old 03-06-2024, 09:40 PM
Cardo's Avatar
Cardo Cardo is offline
Bad motor mount?
"I know just enough to keep me here, but not enough to get me out"
Old 03-07-2024, 09:58 AM
Mounts are fairly fresh. I'll check the return hose, thanks. Could a warn pump do it? What would be the signs of a warn pump? Could running with low fluid wear out a pump?
George
