Old 03-07-2024, 06:52 PM
7t4mula's Avatar
7t4mula 7t4mula is offline
Question Upgrading to 1/2" studs on 1970 12 Bolt Rear axles?
I recently bought a 4 wheel disc brake upgrade kit from Wilwood and didn't realize the front hubs they provided had 1/2" studs. Now I have 7/16 on original rear axle and of course a mixed bag on lug nuts!
How hard is it to convert to 1/2" studs also for back to match the front? Can these be drilled/reamed out on the car easy enough? Wish I would've realized this sooner when I had the rear out for rebuild and new gears! (of course)
Any recommendations on methods or stud manufacturers appreciated! Thx!
Old 03-07-2024, 07:27 PM
Jay S's Avatar
Jay S Jay S is online now
For dirt track stock car racing I recall all the GM cars were required to run 1/2” studs. Many get converted while the hubs and axles were installed on the car. The biggest thing is to find the appropriate drill size for the stud used, then just drill it out. Then shim it and tighten it up to pull it through. Most of the time a drill size can be found that works, but a reamer can work too if it is a little tight.
Old 03-07-2024, 10:37 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
When I bought my wilwoods I had the same problem. I brought my axles to a shop to have them replace the studs and to my surprise all they did was ran a drill bit through the holes and pressed in the studs. I could have done that but was expecting to see them use a drill press or something other than a run of the mill cordless drill. Just get the right size bit which matches the studs and have at it. You're not stepping up the hole size that much so it's easy to keep the hole straight. I got all my studs and lug nuts at the local auto parts store.
67 Firebird Convertible
Old 03-08-2024, 03:59 PM
7t4mula's Avatar
Thanks guys this makes me feel a lot better about doing the job myself on the car. I'm a retired Tool & Die maker, so I should be able to drill some straight holes after 40+ years of that! LOL
I'll have to post some pics of the project once i have time. Its been a long time since I've been active here!
Old 03-08-2024, 05:38 PM
If you have enough material after removing the old studs you can buy screw in 1/2 inch studs. I'm sure Summit has them.
Old 03-08-2024, 08:45 PM
7t4mula's Avatar
That’s a good suggestion as well!
With the tap drill size for a ½-20 being 29/64 (.453”) there should be enough material I’d hope.
Once I get the car back from body/paint I’ll knock the studs out and see what I can do there! 👍🏻
