Still playing with wiring. Question is engine wiring harness. The wires going across to the oil sender coil and 400 turbo wire do they ride above the throttle cable or do they go under and rest on top of the bell housing? Oil line seems too short if they lay above the throttle cable. Is there anything that secures them?
I also need to know dome light routing. Does the power go through the flat harness that services the tail lights then go to dome over the left wheel house? Or is there a separate harness for the dome light? Using M&H harness.
Issue solved.
| The Following User Says Thank You to 1950Mercury For This Useful Post: | ||
