In progress with re-build on a stock W72 and want to keep it close to that with the refresh. Have read all, if not almost all, of the threads on the plethora of cam choices. Heard the videos capturing the idle on the Summit 2800 and 2801 cams, as well as the Lunati.
Seems wide support for the Crower 60240, though have not been able to find any videos of its idle. Realizing the choice of exhaust will affect the tone, would like to hear the idle sound to see just how smooth. Anybody running that 60240 cam in a 400 and have a vid to share? Kindly advise. Thanks so much! |
How is your car geared?
Does it have AC? The factory put a lot of thought into the 402 cam that was fitted to the 78 and hence the 79 W72 motors. It’s been found over the years that your motors stock 402 cam performed the darn near equal of the factory 067 cam, but for maybe a 4 Hp difference on the top end . To this day I am surprised that no one has ground up a high lift version of the 402 cam. Peak Hp with the 402 cam was at about 4300 rpm which even with 3:23 rear gears was a real good place to be. Don’t make yourself crash on a rocky shoreline by picking a cam by exh sound when you only have a 8.2 comp motor at best.
I had a Summit 2800 cam in my low compression 400 w 4 speed. Very good low end torque and a kick to drive. Summit sells it for 243 Bucks with lifters and you can use stock valve springs.
1979 Trans Am WS-6 .030 455 zero decked flat pistons 96 heads with SS valves 041 cam with Rhoads lifters 1.65 rockers RPM rods 800 Cliffs Q Jet on Holley Street Dominator ST-10 4 speed (3.42 first) w 2.73 rear gear __________________________________________________ _______________________________ 469th TFS Korat Thailand 1968-69 F-4E Muzzle 2 |
My brother, Dan, rebuilt two different W72 400 engines, a ’78 and a ’79. The ’78 W72 was the original engine in his ’78 WS6 TA which was modified in an earlier life, then removed for an SD-455 engine. The original 400 (completely torn apart with original rods missing) was already .030” over and needed .040” over pistons to clean up the cylinders properly (so new custom forged pistons and Eagle H-beam forged rods, but ignore this if your short block is good). With rebuilt stock 6x-4 heads minimally cut for trueness, new Ferrea 1-pc stainless valves, CC springs, etc., the static compression worked out to 8.75 to 1. He installed a Summit 2800 cam with old (never used) Crane hydraulic lifters, old factory RA exhaust manifolds, original factory cast iron intake manifold and original Q-jet rejetted for more power on the dyno. With the small 2800 cam, it made 360 hp/456 lbft torque (at 5000/3600 rpm respectively).
The ’79 W72 was a stock std. bore rebuild (new rings on original cast pistons) with minimally cut 6X-4 heads, new valves, etc., stock manifolds (intake & exhaust) & Q-jet. The static compression was 8.10 to 1. Dan had a custom cam (CC) made with 201/219/110 @ .050” with .420”/.450” lift to try to emulate the original ‘402’ cam specs as much as possible from their standard lobe selections. It made 329 hp/413 lbft torque (at 4900/3400 rpm respectively). This was through stock exhaust manifolds and 2.25" headpipes (not mandrels bent pipe). Steve25 is right on with the ‘402’ cam being a pretty good grind and the Summit 2800 and the Crower 60240 cams are good replacements. The 60240 would probably like more compression in the 8.5-up range, however, we’ve never used one yet. Dennis |
The Following User Says Thank You to SD455DJ For This Useful Post: | ||
Cam Quandary
An In-Depth Look at the '77-'79 T/A 6.6 Camshaft Specs https://www.motortrend.com/how-to/hp...-cam-quandary/ .
Steve C. - thanks so much for the article, very helpful!
Steve25,
Thanks so much for your suggestions. My car is all stock and that gearing for the stock 4-speed transmission is 3:23. The car does have A/C. Not trying to make the car more than what it is just want to have a smooth idle and decent power, mindful of the low compression of these late ‘70’s blocks. Thus, just trying to choose the right cam. |
I don`t have a vid but, I did install the 60240 in a bone stock PWH `79 400. It had Doug`s headers and a Performer intake. Still had the stock heads and springs. Car ran well. When cold, one could hear the cam. As it warmed, pretty smooth. This is with headers. With manifolds, I doubt if the "cam" sound would be there.
Seemed to pull to 4800 to 5200 and fall off sharply. Could have been the stock springs but didn`t hear anything bad going on. It does have a lower lift and gentle lobes that one could use stock springs. I put the intake and headers on as it wasn`t my car and that`s what the owner wanted. The engine had 48,000 miles and was un touched. `79 black/gold SE with WS6. Nice car. |
Did the above still have its EGR and stock carb ?
Me? Stock carb and no egr. Did add Comp 1.52 roller rockers and poly locks. A little tidbit I should have added above.
Guy was actually a mopar freak. He said he would never sell that Poncho. That`s what happened. All classic cars got sold except the T/A. Last one to go was a `70 Challanger R/T. 440, 4 speed, dana 60. Red with black vinyl top. Amazing. He sells a car just under a hemi E body and keeps a low compress poncho.
![]() True story. I`m guessing the looks AND the handling was too much for him go go back to old mopar handling. I did have fun for around 6 months driving that thing around with the stick and having the kids checking it out at red lights in mom`s suv.. Brought it to a few car shows. Painted the intake blue. Could hear some folks at the shows talking to each other about the "big block'. ![]() Last edited by PunchT37; 03-16-2024 at 05:33 PM. |
Dennis,
Thank you for that history - interesting real world examples! Fascinating too about the “402” recreation vs. the Summit 2800. Seems that the Crower is good too, but apparently runs out of steam above 5000. Cliff says that this 60240 is the one that has been the most overall successful with these lower compression 400’s, though the data on the 2800’s sure is impressive. Would still like to hear what the Crower sounds like, though it is reported to be smooth on idle. |
Interesting to see the 0.050 specs on the W72 cams. 0.050 close to what my '97 Vortec 350 truck motor has!
The Summit 2801 in the 93cc 6X-4 heads on the flat top piston 400 in my 81 TA is about the same idle as my 78 TA had. Decent power RA exhaust manifolds into 2./5" dual cats(they were still smog testing here when I put it together.
Stated... "Seemed to pull to 4800 to 5200 and fall off sharply. Could have been the stock springs but didn`t hear anything bad going on."
Might of been nose diving due to inadequate pressure to control the valvetrain mass. "The valvetrain is one of the areas where properly matched parts are vital to ensure that the engine functions properly and the valve springs are the key to this." Valve springs often loose pressure over time. To the OP. If the springs are old. Replace them. Not a place to cheap out ! . .
After running a 2800 and 2801 and a 068 cam in a 350, The 2801 shouldn't be to much cam in your 400 with a stick it has more low end torque than a 068 and will have more legs than a 2800
If your not at the table you're on the menu A man who falls for everything stands for nothing. |
![]() Quote:
A reality check is in order here. IF you cam one of these late model low compression 400's with enough duration to pull HARD to and past 5000rpms you are going to have to drop it off a floor jack to spin the tires from a stoplight! Compression is your friend with these things, and your enemy. Unless you have 6X-4 heads that have been milled down a bit, flat top two valve relief pistons close to zero deck, and a thin head gasket to get the squish tight and compression up to at least 9 to 1 looking at cams with enough duration to make strong upper mid-range and top end power is a complete waste of time.
The 4 speed and 3.23's help some here but it doesn't appear we're going to have much past 8 to 1 compression when it's all said and done. It also appears that idle sound is on the list of requirements. You just can't have your cake and eat it to with a 400 build at 8 to 1 compression pushing around a car weighing 2 tons. Big cams with a lot of overlap are not on the list with these builds. I have typically avoided "low" compression 400 builds over the years as most customers I've had were wanting a stroked version or going to early heads to get the compression up some. They already knew those engines were turds right out of the box and had owned the cars long enough to want to up the power considerably. The few that I got involved with early on educated me to stay away from larger cams in them. One was brought here to custom tune that had the Summit 2801 cam in it. It was really "soft" off idle and didn't start pulling well till 3000rpms or so. Had another in here with a Comp XE262 cam in it, what a gutless turd that was. Even got involved with one that supposedly had the compression raised some and Comp XE268 cam, it was even a bigger turd! I've also been around a few with the Summit 2800 cam in them and they were remarkably smooth at idle compared to the Crower cam. That would be a close second choice for one of these engines if I were building it here and the customer wanted stock type idle and good street manners. I'm mentioned several times on here over the years that the first engine in my Ventura had 6X heads on it and the Crower 60240 cam, 210/221/112 LSA. Idle quality was decent, just a hint of a larger cam going on in the idle note. Strong mid range power and pulled really hard to 5000rpm's, and excellent street manners.. With 2.73 gears, TH400, and a stock converter it ran 14.0's @ 99-100mph at the track on BFG street tires. Best run ever in really good air and track conditions was 13.87 @ 101mph. That's getting it done pretty good for a pretty much stock late model 400 build with unported 6X heads on it......
My question about the removal of EGR to run the performer and the use of a stock carb From a EGR motor is due to the leanness that will take place when the EGR system is made inoperable and then responce from the motor will ping and surge.
I cringe when hear that on any car be it Pontiac or whatever that someone has disabled the EGR system and now has ping and off idle carb response problems.
I disabled the EGR on my old stock 180 HP 78 motor when I swapped on a 72 HO intake no pinging. The 400 in the 81 has a plain performer(although I have an EGR one if we ever get that much govt inspections!) and no pinging.
One more note on the pull hard to 4800-5200 rpms then drop off sharply.
CLASSIC symptoms of sucking the bowl dry on the carburetor. More times than not that's going to be the issue vs weak valve springs or something not up to par in that area. I usually look there before diving into the engine to see if there are valve train related issues......
