C clip eliminator axle bearing interference fit specification
Looking to change my 10 bolt BOP to a 12 bolt. I just picked up a 12 bolt housing that came with C clip eliminators, I have some Yukon axles but it looks like the interference fit of the bearing onto the axle is excessive (about 0.003" interference fit) my concern is that the bearing will run hot and fail prematurely. Bearing journal of shaft is 1.3995". Does anyone know if this is with-in tolerance?
1972 GTO 468 2 Bolt Main w/Eagle rotating assy SD Ported 295 KRE D Ports 10.8 CR OF Hydraulic roller w/ 1.65 stainless rockers Performer RPM Intake Holley 3310 780 Vacuum Secondary TH400 with 10" Continental Convertor 8.2 BOP 4 pinion 10 Bolt with 3.36 gears 11.428/118.95/1.618 |
