Old 03-18-2024, 10:01 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Default Chicken wire
Exactly when was chicken wire started and stopped during Pontiac production? How far in the 69 model year was the chicken wire used?
Old 03-22-2024, 08:52 PM
grivera's Avatar
grivera grivera is offline
Where does it go?
Will Rivera
Old 03-22-2024, 11:36 PM
Underneath the bondo along with wet newspaper.
He talking about the cowl vent screening.
The Following 4 Users Say Thank You to b-man For This Useful Post:
Old 03-23-2024, 02:48 PM
Cammer-6 Cammer-6 is offline
roofing tar is cheaper than bondo
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 03-23-2024, 03:19 PM
GTOLiam's Avatar
GTOLiam GTOLiam is offline
sounds easier to work with than old road signs and pop rivets....thanks!
"Hammer to fit, paint to match"
Old 03-24-2024, 09:27 AM
Andretti's Avatar
Andretti Andretti is offline
I believe the cowl screens using metal mesh was used on all '69s with '70 changing to the 3 plastic inserts.
Old 03-24-2024, 08:59 PM
tremo's Avatar
tremo tremo is offline
I replaced the chicken wire on my '69 Custom S with the plastic inserts from Ames for '71-'72. Well worth the $23 and look is a lot cleaner. Just pop them right into place.
* '69 Custom S - 2dr Hardtop Coupe - Rust-free Oregon survivor with all original panels and original trunk floor
* Engine alive and kickin' March 2nd, '06
* RA-IV 'spec' 400 (.060-over = 410ci), balanced, Comp Cams #9794041, #16 heads (72cc converted to large valve) with 1.65 Harland Sharp Rollers
* QuadraJet #7042210, HEI, Hurst V-Gate, FlowTech Headers, X-Pipe with dumps, Flowmasters, TH-350, 3.90 Posi
* Best ET: 14.06 - Bandimere Speedway, CO. @ 5,800+'
Old 03-25-2024, 01:14 AM
Scott Thelander's Avatar
I think 70 it started
Old 03-26-2024, 07:57 AM
etennett etennett is offline
My 68 has original mesh with 4 screws and a clip. It may have started before 68
eric
Old 03-27-2024, 12:33 PM
grivera's Avatar
Good to know it fits!!
Will Rivera
Old 03-27-2024, 01:42 PM
grivera's Avatar
Thanks - funny cause when I found that chicken wire on my 69’s cowl I thought someone made it at home…now I don’t know - I set aside with the garage trash but haven’t discarded it yet.
Will Rivera
Old 03-27-2024, 02:23 PM
OG68 OG68 is online now
Chicken wire was used in the 68/69 Pontiac A bodies.
However, the plastic inserts are shown in the 69 assembly manual in addition to the screen.
I don't ever recall seeing a 69 with the plastic inserts however. I always thought the plastic was used for the 1970 models
68 / early 69
It appears the changeover to plastic was around Feb '69
with an update in Mar '69
ID:	631178   Click image for larger version
ID:	631179   Click image for larger version
The Following 2 Users Say Thank You to OG68 For This Useful Post:
Old 03-27-2024, 04:14 PM
not on any 67s Ive had
Old 03-28-2024, 07:55 AM
gto4evr gto4evr is offline
there was a thread awhile ago about this. they were probably using up stock before the changeover if it was intended for a Feb 69 change date. I've never owned or seen an original 69 with the plastic. of course as a punk kid with my first 69, that was the first thing I tore off the car and replaced with the plastic because I was sure it was some hack job from a previous owner! getting tougher to find an original car that hasn't been "fixed" in the last 55 years.
side note, if you're chasing an original screen with the correct contouring vs the junk flat repops - 69 GP used the identical screen. I scored one off ebay a few years ago on a gamble and it was exact.
