Old 03-20-2024, 10:02 AM
napster's Avatar
napster napster is online now
Default Experience & Opinions on Brawler Carbs
Wondering what people have experienced with the Brawler Carb. I have one on a 496 engine. It is a 850 CFM with mechanical secondary. Works very well for me.
The Following User Says Thank You to napster For This Useful Post:
Old 03-20-2024, 10:23 AM
prostreet64's Avatar
prostreet64 prostreet64 is offline
I have the 950 with mechanical secondaries. When I first installed the carb it was flooding and I couldn't find the cause so I sent it back to Holley and they went through it and it has worked perfectly since then. I will say that the Brawler series is very sensitive to fuel pressure.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet.
Old 03-20-2024, 10:49 AM
i82much's Avatar
i82much i82much is offline
Can't speak to Brawler specifically but had a few cheaper Holley and Quick fuel carbs that were lacking in quality control, and found that trading those for more expensive holley/qf carbs did not exhibit the same issues. My impression is that the quality control is stricter on the more expensive carbs.
The Following User Says Thank You to i82much For This Useful Post:
Old 03-20-2024, 02:20 PM
West Coast GTO's Avatar
West Coast GTO West Coast GTO is offline
Bought and installed a Brawler 850 double pumper and had trouble setting idle initially. Adjusted bottom slot correctly and ran pretty well but am changing out to go with Cliff rebuilt Quadrajet.
The Following User Says Thank You to West Coast GTO For This Useful Post:
Old 03-20-2024, 03:09 PM
mgarblik mgarblik is offline
I have had at least 1/2 dozen students buy and use them in various configurations in my class. We ran all of them on the engine dyno. For the money, they are a decent carburetor IMO. They do take some tuning as all carbs do to optimize on the dyno. We had one that had weird cross threading of the fuel inlet nut as delivered and leaked fuel like crazy. Called Holley and asked for a replacement fuel bowl. They said just keep it and sent another complete carburetor. So that tells you they probably have less than $50.00 in the whole thing. Certainly not the worst carburetor out there and way, way better than the Edelbrock AFB knock offs. BTW, the Brawlers are a great buy on the Holley refurbished web page. There are usually quite a few available for around three hundred dollars.
Old 03-20-2024, 06:50 PM
PDC PDC is offline
Hey Napster! This is a bit off topic. I hope you don’t mind and I hope this helps someone. When I bought my Red ‘73, the engine had been re-built and topped with a true Holley 750HP. Car flick started, idled clean, and ran like a top. Over time, I encountered a few drivability issues with Big Red, and my local mechanic did a simple rebuild of the carb with a new Holley gasket and O-ring set. Car returned to driving like it had fuel injection.
I didn’t know anyone locally familiar with Q-Jets, so when the time came for a new carb on my Green car, I went with a Holley ‘Street’ HP-750. I wan’t trying to pinch pennies by any means. But the car always ran pig rich and fouled plugs like crazy. My mechanic was more than willing to re-jet the ‘Street’ HP and swap the Power Valve to match the specs of the true OG ‘HP’ but instead, he said: ‘if you like the way your Red car runs, just get a real HP-750 for the Green car.’ I did and never looked back. Set the 4-corner and idle speed and the Green car ran like it had fuel injection. Flick started, ran strong and clean, plugs looked perfect.
If your Brawler ever starts bucking or surging or otherwise disappointing you, I wouldn’t hesitate to go with the OG ‘HP’ series Holley in whatever CFM your mill requires.
I love my new Black Car - but FWIW, you really DON’T know what you have til it’s gone. I didn’t know how much I loved my Green and Red ‘73s till they were gone. That said, I don’t have Jay Leno’s garage space or $$, so my various car experiences are enjoyed 1 or 2 (max) at a time!!!
The Following User Says Thank You to PDC For This Useful Post:
Old 03-20-2024, 06:58 PM
64speed's Avatar
64speed 64speed is offline
Mine took some setup but runs great. 750 DP gets about 15 mpg with the TKO and has great tip in and part throttle cruise.
Old 03-21-2024, 08:23 AM
napster's Avatar
PDC,
That is great advice. The Brawler right now is working fine. If it acts up I will go with the advice.
One of my other cars, a 1970 T/A, has a hard to get Holley 780 cfm with vacuum secondaries on a reproduction Ram Air IV intake manifold that was on the car when bought. However, I am now running into major problems with the intake creating 2 major vacuum leaks. When the leaks are not there the engine runs great. Got sick of the problems it created and had to buy the real deal Ram Air IV intake.
Jim
Old 03-21-2024, 10:46 AM
GTO-relic GTO-relic is offline
I bought a reman/return Brawler direct from Holley. 750cfm
just another take on an old 4779 DP, with a facelift, IMHO.
never used it. sold to a friend at cost, he put it on a 6.0 LS in a truck,
it ran great, instant response, boiled the tires viciously.
then he sold the truck. that's all I can say about that.
for the money ? I'd rather put a kit in a decent core 4779 DP 750
the name and the gaudiness of the Brawler is not my style or image
take the Brawler name off it, not a bad carb, but then it's just a 4779-whatever
lol it's all marketing...the modern car parts names just sounds juvenile and silly to me.
