Old 03-21-2024, 09:24 PM
1bad65's Avatar
1bad65 1bad65 is offline
Default 1965 GTO Windshield & Rear Glass Install
Hi. Does anyone know the thickness of the Butyl tape used to install the front windshield and rear window on a 1965 GTO? I know it may differ slightly from car to car but there must be an average size that was used. Bodyshop set glass to low using black window sealer and now there's a gap between the glass and molding. Any help is greatly appreciated.
Old 03-21-2024, 09:44 PM
OG68 OG68 is offline
Body shop should have used spacers to set the glass.
Scroll down to bottom of the page.
https://www.rustreplace.com/home/tec...tips/downloads
2007 Cadillac SRX
Old 03-21-2024, 10:32 PM
GtoFM's Avatar
GtoFM GtoFM is offline
I would pick up a set of spacers and have the body shop fix their mistake.
Old 03-22-2024, 06:58 AM
1bad65's Avatar
Yes, that is the plan. Thanks.
Old 03-22-2024, 06:59 AM
1bad65's Avatar
Thanks for the information, appreciate the response.
Old 03-22-2024, 08:16 AM
chrisp chrisp is offline
The 5/16" square size will work with factory glass. Thinner aftermarket glass will need a thicker 3/8" square size. Prime both the pinch weld and glass surfaces with pinchweld primer [black rubber], once glass is set put a thin bead of urethane between the edge of glass & butyl , smooth with popsicle stick that will seal it up. The only spacers required are two rectangular spacers to support the glass from sagging down , they can be made from any rubber or plastic . Flat spacers will not be necessary since the butyl tape will provide the support and height.
Old 03-22-2024, 03:38 PM
1bad65's Avatar
Thanks for the information, I will pass it on to the shop.
Old 03-22-2024, 07:14 PM
Due to the age of our vehicles and the unknown quality of the imported glass, I think it's important to dry fit the glass first and cut the spacers to the thickness required. You want the glass molding to lie flush with the glass and the body. The link below shows how to do that.
https://drive.google.com/file/d/1ZSA...s2pGJp4Rj/view
2007 Cadillac SRX
Old 03-22-2024, 08:47 PM
GtoFM's Avatar
My 64 is nowhere close to installing glass, but I'm all ears. Is all aftermarket glass thinner or only certain sources? Is there as standard thickness or dependent on year?
Old 03-22-2024, 09:23 PM
1bad65's Avatar
Thanks again. I read through all the information you sent last night and found it extremely valuable. I plan to share it with the shop that is working on my car. A must read for all re-installing or installing new glass. Have a great weekend.
The Following User Says Thank You to 1bad65 For This Useful Post:
Old 03-22-2024, 09:24 PM
1bad65's Avatar
You should read the information OG68 provided. Very informative. Thanks and good luck.
Old 03-22-2024, 09:56 PM
GtoFM's Avatar
Thanks bad, I overlooked the link in OG68's post.
