Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 03-30-2024, 02:29 AM
Bob Eiler's Avatar
Bob Eiler Bob Eiler is offline
Default 428 BLOCK & CRANK
2 bolt 428 bare block and crankshaft / 030 over with less than 10,000 miles on rebuild. Cylinder walls are excellent condition and has been stored with greased cyl. walls. The crank is 20 under and only needs polishing. Local pick up only. I live 8 miles south of Dayton Oh. $500
There is no such thing as too much cam, just not enough engine.
1966 GTO - 11.31@119 (3478 lbs) in 1979
1967 Firebird - 9.73@138 (2940 lbs) in 1986
400 cu in / 295-298 cfm RAIV / Lunati Cam 278/283 - .704 lift/5.13 gears
The Following User Says Thank You to Bob Eiler For This Useful Post:
