Old 03-30-2024, 06:03 PM
67drake's Avatar
67drake 67drake is offline
Default What tool?
Makes these flares. Seems I’m bending my own fuel lines often, and some cars ( this is an old Mercury ) run inline fuel filters. I like to have a little flare in it for safety.
‘55 Catalina
Old 03-30-2024, 06:05 PM
67drake's Avatar
Sorry, pic didn’t post-
‘55 Catalina
Old 03-30-2024, 07:43 PM
Formulas's Avatar
Formulas Formulas is offline
Beading is the process
........... The More You Follow The Herd The Less You Can Be In The Lead ..........
The Following User Says Thank You to Formulas For This Useful Post:
Old 03-30-2024, 08:09 PM
I’ve used a double flaring tool and stopped part way through the first flare to end up with something close to that.
The Following 6 Users Say Thank You to b-man For This Useful Post:
Old 03-30-2024, 11:02 PM
There used to be a tool for raising the surface of the tube because I used them when I was in school many years ago. I don't know if they are still made or not. It slipped inside the tube and expanded it from the inside.
Old 03-30-2024, 11:27 PM
Shiny Shiny is online now
Being ignorant of this topic, I went clicking and stumbled on this bead former made by Graham:
https://www.grahamtool.com/tube-bead...e-beading-tool
Looks like a nice tool but not inexpensive.
Maybe there are more budget-friendly knock-offs? Or maybe you could find a local shop, like a hose fabricator, with a commercial version that could do it for you?
I'd be trying b-man's approach on my budget.
Name:	Bead Former.jpg
Old 03-31-2024, 02:33 AM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
Something like the flare on the bottom sample?
Name:	Image 3-31-24 at 1.31 AM.jpeg
Old 03-31-2024, 09:06 AM
pfilean's Avatar
pfilean pfilean is offline
I'm to cheap to go looking for an expensive tool. I often just solder on a ferrule from compression fitting. It's a little too big, so you then have to grind off some of it. I know it doesn't look OE but it is always hidden under the rubber tubing and probably behind a spring type hose camp.
The Following 2 Users Say Thank You to pfilean For This Useful Post:
Old 03-31-2024, 01:21 PM
Jim Scites's Avatar
Jim Scites Jim Scites is offline
How about an AN to Barbed fitting? Then just flare the steel line?
Go Fast... Return... Go Fast Again... Who cares about left turns???
Old 03-31-2024, 01:30 PM
Thumbs up
Yes that’s pretty close to what you want.
Old 03-31-2024, 01:41 PM
67drake's Avatar
Yes. I’ve put regular single flares in lines in the past, and it can be a pain to get the lines on. It doesn’t have to be perfectly like the bubble I pictured, but something to hold the rubber line in place.
This is what was coming out of my fuel pump, and then 2 1/2’ of rubber line to the filter, a liability!
Rather have a tool, than rely on having fittings and such around that I always seem to be out of.
Thanks everyone.
‘55 Catalina
Old 03-31-2024, 08:17 PM
mgarblik mgarblik is offline
I have made hundreds of feet of fuel and brake line with the Mastercool hydraulic flaring tool. It's a little pricy but does it all. Double flare, ISO flare, quick disconnects, barbs, it does it all. 3/16-3/8".
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
Old 03-31-2024, 10:20 PM
george kujanski's Avatar
I use the mastercool tool and just use a partial squeeze with the first flare step of a double flare process, as mentioned above
George
The Following 2 Users Say Thank You to george kujanski For This Useful Post:
Old 03-31-2024, 10:25 PM
77 TRASHCAN's Avatar
I bought one of those kits, several years ago. It's the ONLY tool to use!!!
Throw your old flaring tools in the trash!!!
Shut it off
Shut it off
