Old 04-04-2024, 09:35 PM
grd777 grd777 is offline
Default having trouble installing my rear seats
I installed the rear seat belts ,hopefully the correct way . Seems that the rear seats will not fit because the seat belts are in the way .What am i doing wrong. These are the original seats and belts to the car
ID:	631544   Click image for larger version
Old 04-05-2024, 07:29 PM
Do the rear seat belts look correct
Old 04-05-2024, 07:51 PM
Did your car originally have the retractable belt?
I'm never seen one, so no help. I do know they are different than the ones for the front seats.
Old 04-05-2024, 08:08 PM
Held for Ransom's Avatar
Those belts have the hook up for the shoulder belts (fronts). Pictured is a '74, but '73 should be the same.
So long, farewell.
Old 04-05-2024, 08:22 PM
Judge273's Avatar
Judge273 Judge273 is offline
Is your car a 71?
Mike/Illinois
Old 04-05-2024, 08:41 PM
My car is a march 1972 , those are the ones I got with the car. Maybe they are not suppose to be retractable
Old 04-05-2024, 08:42 PM
Is your car a 71?
March 72
Old 04-06-2024, 05:31 AM
Judge273's Avatar
FYI, Those seats are for a 71.
Mike/Illinois
Old 04-06-2024, 07:09 AM
cnc's Avatar
cnc cnc is offline
Just askin how can u tell by looking at the seats????.
Just for more belt clarification…..These rear belts are on my 73 …..
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 04-06-2024, 08:09 AM
For some reason, I thought OP was working on a '73. My info isn't right for him.
So long, farewell.
Old 04-06-2024, 08:49 AM
Is the carpet making the belt housing tilt inward too much?
Trim the carpet away from the mount?
Old 04-06-2024, 08:53 AM
Will take a look
Old 04-06-2024, 08:58 AM
cnc's Avatar
cnc cnc is offline
Possible…..????
Old 04-06-2024, 09:01 AM
Wow how can you tell. Are the 71 seats different at the bottom for this type of seat belt
Old 04-09-2024, 05:20 AM
Judge273's Avatar
71 F body deluxe seats are comfort weave insets and are ivory color.
72 F body deluxe seats are perforated insets and are white color.
Mike/Illinois
Old 04-09-2024, 12:04 PM
unruhjonny's Avatar
I was going to say that from the factory there was no carpet under the seat;
It went up over the lip, but did not extend that far back.
(I believe I photographed my cars carpet install before replacing the carpet in the early 2000's)
It seems that most people leave the carpet there - and this shouldn't be a bid deal...
I do believe that the seat rear bottoms which had retractable (male) belts had indentations to clear the retractor - but I do not believe that the cars which had a standard length belt (as '71 ect would have had) had these indentations;
I would think the seat should still fit, but might be a bit tight.
Another question;
If you have left carpet under the seat bottoms;
Have you omitted the vinyl between the seat bottoms, or placed the vinyl (presumably with burlap backing) on top of the carpet?
adding material on the driveshaft hump, as well as adding retractable belts may only compound your problem.
1970 Formula 400
Old 04-09-2024, 02:44 PM
Another question;
yes i think you are correct i will need to trim back some of the carpet and see what happens . thanks for everyone's input
Old 04-09-2024, 03:01 PM
fbody_mike's Avatar
fbody_mike fbody_mike is offline
With those buckles on the rear lap belt, should this car have had the rare rear seat shoulder belts?
I built it one piece at a time and it cost me more than a dime.
Old 04-09-2024, 03:02 PM
i do not think so , but not sure
Old 04-09-2024, 03:09 PM
unruhjonny's Avatar
I have pictures somewhere, but as I recall the rear shoulder belts were essentially the same as the front shoulder belts;
The interlocking belts were 1972.5 & 1973;
I do not know if the rear belts were offered during that time.
1970 Formula 400
