Old 04-11-2024, 04:24 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Default Factory 1969 GTO 8.2 10 Bolt Rear End Nodular 3.55 w 4 Piston Calipers
I went to a Moser 12 bolt, I regretfully am selling my stock rear end.
1969 GTO factory 8.2, 10 bolt, N stamped with 3.55 rear end.
Comes with Aerospace 4 piston rear brakes, 11.75" rotors.
The brakes alone with the help to mount with Aerospace is almost $900. These are great and the car stops awesome.
Never damaged, never axle swapped, I've had the car since 1996 and never did anything to this to harm it. Though personally I have less than 5000 miles driven but it's been well taken care of.
I'm in Illinois
I stand behind my parts
It will be at the shop for pick up etc.
I don't really know the true value but I know it's a car not getting any younger and factory parts make the restorations valuable.
$2200 (open to reasonable offers unless I find out these sell for more LOL)
Email me at gnvyus1 @ hotmail.com (space done for bots)
ID:	631923   Click image for larger version
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
Old 04-16-2024, 11:26 AM
GOAT8U2's Avatar
I'm throwing in QA1 rear single adjustable shocks, low low miles.
More pics included
ID:	632139   Click image for larger version
ID:	632140   Click image for larger version
ID:	632141   Click image for larger version
ID:	632142   Click image for larger version
Old 04-18-2024, 05:18 PM
GOAT8U2's Avatar
Currently the wheels on the rear end do NOT come with it.
QA1 shocks are $200 each new so in throwing in $400.
$2200
I can have a shipping option if you're within 5 hours 1 way.
A guy will do this starting at $250.
Looks like shipping is around $700 on a pallet etc, wow.
Old 05-07-2024, 01:38 AM
GOAT8U2's Avatar
Gotta get a new driveshaft as the Moser 12 bolt need a shorter one.
I'm putting my 3" steel shaft for auto TH400 for sale, it has 1300 miles on it.
Factory 8.2 rear end
Aerospace disc brakes
QA1 single adjustable shocks
3" steel driveshaft
$2500
Great restoration swap
