Old 04-14-2024, 03:18 PM
FunctionalShaker FunctionalShaker is offline
Default 70 Small Splash Shield
Looking for pics of the rubber piece that attaches vertically, 3 staples, at the back of the wheel wells (covers the brake line connection). The pen points to where it goes.
They repop the bigger one, but not these.
Any help is appreciated.Click image for larger version
Sent from my SM-A125U using Tapatalk
Old 04-14-2024, 11:51 PM
No one?
Old 04-15-2024, 05:25 AM
Red80TA Red80TA is offline
8hrs.
#1480309 10x13" Rubber. Fitted as required and how required, cut to fit. Earlier number/version #479582.
1480309 NOS GM fender chassis hood rubber seal by Ben, on Flickr
73 Firebird RH inner fender stapled rubber dust shield and insulator 1480309 and AC muffler bracket (4) by Ben, on Flickr
71 TA inner fender to chassis rubber insulation 1480309 by Ben, on Flickr
Old 04-15-2024, 06:48 AM
Interesting. So more of an anti rub/squeak piece.
The Following User Says Thank You to FunctionalShaker For This Useful Post:
Old 04-15-2024, 07:17 AM
Assuming I have the piece you are talking about, yes, just a rub panel between fender and chassis rail. So, was that of use?
Old 04-15-2024, 07:59 AM
Yeah, I imagine it has some thickness to it, so the staple doesn't stick out and rub.
Old 04-15-2024, 09:29 PM
hiyabradHO hiyabradHO is offline
When restoring, which set would I buy for my "71 TA and which staples? How were the staples installed? We there already holes in the sheetmetal or was it actually stapled?
The Following User Says Thank You to hiyabradHO For This Useful Post:
Old 04-17-2024, 11:42 AM
comanchefirebird comanchefirebird is offline
Checked a couple of 70's in storage.
The small flap at the back is 1" x 6.5 inch
They are the same material and thickness as the main inner fender flaps
Attached two pics (one with, one without flash) of the flap on a 1970 left inner fender in storage
ID:	632217   Click image for larger version
The Following User Says Thank You to comanchefirebird For This Useful Post:
